Annotation Layers in ArcGIS Runtime SDK for .NET
1409
7
03-11-2020 09:27 PM
JamieBurmeister
New Contributor II
I'm trying to add the following Esri.ArcGISRuntime.Mapping.AnnotationLayer to my Esri.ArcGISRuntime.Mapping.Map but I get a LoadError on Loaded.
Layer Source: https://maps.cern.ch/arcgis/rest/services/General/General/MapServer/45
Layer Type: Esri.ArcGISRuntime.Mapping.AnnotationLayer
Layer Display Name: Voirie_texte
Exception:
Esri.ArcGISRuntime.ArcGISRuntimeException: Invalid response    at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)    at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)    at System.Runtime.CompilerServices.TaskAwaiter.GetResult()    at Adapt.Presentation.Esri.LayerConfigPersister.<ConfigureLayer>d__15.MoveNext() in C:\Users\Laura\RiderProjects\AdaptSource\src\Adapt.Presentation.WPF\Adapt\Presentation\ESRI\LayerConfigPersister.cs:line 120
Any and all help appreciated.
MichaelBranscomb
Esri Frequent Contributor
What's the call stack include if you enable native debugging and reference the symbol files? (see https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-net/blo...)
Thanks
Mike
JamieBurmeister
New Contributor II
>    Esri.ArcGISRuntime.dll!Esri.ArcGISRuntime.Mapping.Map.InitLoadable.AnonymousMethod__0(object s, System.EventArgs e)    Unknown
     Esri.ArcGISRuntime.dll!Esri.ArcGISRuntime.Internal.LoadableObjectHandler<System.__Canon>.OnLoadEnded()    Unknown
     Esri.ArcGISRuntime.dll!Esri.ArcGISRuntime.Internal.LoadableObjectHandler<RuntimeCoreNet.GeneratedWrappers.CoreMap>.RuntimeCoreNet.GeneratedWrappers.ICoreCallback_Loadable_DoneLoading.DoneLoading(RuntimeCoreNet.GeneratedWrappers.CoreError loadError)    Unknown
     Esri.ArcGISRuntime.dll!RuntimeCoreNet.GeneratedWrappers.CoreMap.onPrivateCoreLoadable_DoneLoading(System.IntPtr loadError)    Unknown
     [Native to Managed Transition]
     runtimecore.dll!std::_Func_impl_no_alloc<<lambda_810e53070115a1e048bfb9eaf8a6e643>,void,void *,Esri_runtimecore::Common::Error const &>::_Do_call()    Unknown
     runtimecore.dll!std::_Func_impl_no_alloc<<lambda_32601c908543cacb3556b7ea268514e6>,void,Esri_runtimecore::Common::Loadable &,Esri_runtimecore::Common::Error const &>::_Do_call()    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Loadable::set_load_status_and_error_without_check_(enum Esri_runtimecore::Common::Load_status,class Esri_runtimecore::Common::Error const &)    Unknown
     runtimecore.dll!Esri_runtimecore::Geo_model::Map::set_load_status_and_error_(enum Esri_runtimecore::Common::Load_status,class Esri_runtimecore::Common::Error)    Unknown
     runtimecore.dll!Esri_runtimecore::Geo_model::Basemap::set_load_status_and_error_(class Esri_runtimecore::Common::Loadable const &)    Unknown
     runtimecore.dll!<lambda>(void)()    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Signal_detail::`anonymous namespace'::dispatch_to_node()    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Signal_detail::`anonymous namespace'::dispatch_notification()    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Loadable::set_load_status_and_error_(enum Esri_runtimecore::Common::Load_status,class Esri_runtimecore::Common::Error)    Unknown
     runtimecore.dll!Esri_runtimecore::Geo_model::Service_feature_table::handle_query_data_elements_response_(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)    Unknown
     runtimecore.dll!Esri_runtimecore::Geo_model::Service_feature_table::handle_response_(class std::shared_ptr<class Esri_runtimecore::Common::Request> const &,unsigned char const *,unsigned __int64,class std::shared_ptr<class Esri_runtimecore::Common::Client_reference> const &)    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Request_delegator::handle_response(unsigned __int64,unsigned char const *,unsigned __int64,class std::shared_ptr<class Esri_runtimecore::Common::Client_reference> const &)    Unknown
     runtimecore.dll!Esri_runtimecore::Common::Request::handle_response(unsigned char const *,unsigned __int64,class std::shared_ptr<class Esri_runtimecore::Common::Client_reference> const &)    Unknown
     runtimecore.dll!RT_Request_handleResponse ()    Unknown
     RuntimeCoreNet.dll!CoreRT_Request_handleResponse ()    Unknown
     [Managed to Native Transition]
     Esri.ArcGISRuntime.dll!RuntimeCoreNet.GeneratedWrappers.CoreRequest.HandleResponse(byte[] data, RuntimeCoreNet.GeneratedWrappers.CoreClientReference userDefinedError)    Unknown
     Esri.ArcGISRuntime.dll!Esri.ArcGISRuntime.Internal.RequestRequiredHandler.IssueRequestAndRespond(RuntimeCoreNet.GeneratedWrappers.CoreRequest request)    Unknown
     [Resuming Async Method]
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Threading.Tasks.VoidTaskResult>.AsyncStateMachineBox<Esri.ArcGISRuntime.Internal.RequestRequiredHandler.<IssueRequestAndRespond>d__18>.ExecutionContextCallback(object s)    Unknown
     System.Private.CoreLib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Threading.Tasks.VoidTaskResult>.AsyncStateMachineBox<Esri.ArcGISRuntime.Internal.RequestRequiredHandler.<IssueRequestAndRespond>d__18>.MoveNext(System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Threading.Tasks.VoidTaskResult>.AsyncStateMachineBox<Esri.ArcGISRuntime.Internal.RequestRequiredHandler.<IssueRequestAndRespond>d__18>.MoveNext()    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.TaskAwaiter.OutputWaitEtwEvents.AnonymousMethod__12_0(System.Action innerContinuation, System.Threading.Tasks.Task innerTask)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncMethodBuilderCore.ContinuationWrapper.Invoke()    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.AwaitTaskContinuation.RunOrScheduleAction(System.Action action, bool allowInlining)    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.RunContinuations(object continuationObject)    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task<System.__Canon>.TrySetResult(System.__Canon result)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Net.Http.HttpResponseMessage>.SetResult(System.Net.Http.HttpResponseMessage result)    Unknown
     [Completed] System.Net.Http.dll!System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(System.Threading.Tasks.Task<System.Net.Http.HttpResponseMessage> sendTask, System.Net.Http.HttpRequestMessage request, System.Threading.CancellationTokenSource cts, bool disposeCts)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Net.Http.HttpResponseMessage>.AsyncStateMachineBox<System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__71>.ExecutionContextCallback(object s)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Net.Http.HttpResponseMessage>.AsyncStateMachineBox<System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__71>.MoveNext(System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.__Canon>.AsyncStateMachineBox<System.Net.Http.HttpClient.<FinishSendAsyncUnbuffered>d__71>.MoveNext()    Unknown
     [Completed] Esri.ArcGISRuntime.dll!Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Net.Http.HttpResponseMessage>.AsyncStateMachineBox<Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__14>.ExecutionContextCallback(object s)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.Net.Http.HttpResponseMessage>.AsyncStateMachineBox<Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__14>.MoveNext(System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Runtime.CompilerServices.AsyncTaskMethodBuilder<System.__Canon>.AsyncStateMachineBox<Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__14>.MoveNext()    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.FinishStageThree()    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.FinishStageTwo()    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.FinishSlow(bool userDelegateExecute)    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.ExecuteWithThreadLocal(ref System.Threading.Tasks.Task currentTaskSlot, System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.ExecuteEntryUnsafe(System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Threading.Tasks.Task.ExecuteFromThreadPool(System.Threading.Thread threadPoolThread)    Unknown
     System.Private.CoreLib.dll!System.Threading.ThreadPoolWorkQueue.Dispatch()    Unknown
     System.Private.CoreLib.dll!System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()    Unknown
     kernel32.dll!00007ffb48677bd4()    Unknown
     ntdll.dll!00007ffb497aced1()    Unknown
JamieBurmeister
New Contributor II
Please check out my GitHub repository for ESRI bug reporting here.
This bug is listed as Annotation Display Bug in the bug selection menu.
JamieBurmeister
New Contributor II
Hey Michael Branscomb‌, have you managed to take a look at this one?
Cheers,
Jamie
MichaelBranscomb
Apologies for the delay.
If you await LoadAsync() with a try/catch or handle the LoadStatusChanged event the LoadError message is `{"Invalid URL."}`.
The issue is caused by attempting to create an AnnotationLayer from a MapServer/<SublayerId> e.g. `https://maps.cern.ch/arcgis/rest/services/General/General/MapServer/45`,
Instead you need to enable feature access to create the FeatureServer/SublayerId endpoint and use that as the Uri instead e.g. https://github.com/Esri/arcgis-runtime-samples-dotnet/blob/master/src/WPF/ArcGISRuntime.WPF.Viewer/S...
Thanks
Mike
JamieBurmeister
New Contributor II
I don't understand, the layer displays fine in other display tools. Can you explain what you mean by "enable feature access"?
MichaelBranscomb
Depending on which workflow you followed to publish the service, you need to enable the `Feature Access` capability:
Setting map service properties—Help | ArcGIS for Desktop
Configure a map service—ArcGIS Pro | Documentation
Thanks
Mike
