Add attachment to a feature using Xamarin Android
1782
08-02-2017 02:47 PM
YifanLiu
New Contributor II
I am adding an attachment to a feature on the feature service. My issue is I am able to add the attachment to the feature, but I am not sure how to push the attachment to the feature service. Here is what I did:
private async void save() {
    await feature.LoadAsync();
    // bytes is the byte array containing data of the file
    var result = await feature.AddAttachmentAsync(App._file.Name, @"image/", bytes);
    ServiceFeatureTable sft = feature.FeatureTable as ServiceFeatureTable;
    await sft.UpdateFeatureAsync(feature);
    await sft.ApplyEditsAsync();
Debugging shows that feature.AddAttachmentAsync() works as expected. After that line, I tried feature.GetAttachmentAsync() and it returns the just added attachment. However, I was not able to sync the attachment to the feature service. That feature service has attachment enabled.
Am I missing any steps here? Appreciate any help.
Best
Yifan
JenniferNery
You can check for `CanEditAttachments` to know if you're able to add/update/delete attachments for the specified feature. You can also check the result of `ApplyEditsAsync` to know whether any of the edit operation failed.
if (feature.CanEditAttachments)
    await feature.AddAttachmentAsync("test.png", "image/png", bytes);
var table = layer.FeatureTable as ServiceFeatureTable;
var edits = await table.ApplyEditsAsync();
var editResult = edits.FirstOrDefault(r => r is FeatureEditResult && ((FeatureEditResult)r).AttachmentResults.FirstOrDefault(ar => ar.CompletedWithErrors || ar.Error != null) != null) as FeatureEditResult;
In your code, is `App._file.Name` full file name including path? This should be file name with extension. And the `contentType` parameter should be one of the MIME types that your server support. (i.e. image/png, text/plain, etc.)
NagmaYasmin
Occasional Contributor III
Hi Yifan,
Have you tried to set up GenerateGeodatabaseParameters.AttachmentSyncDirection to sets the direction for the attachments to be synchronized.
GenerateGeodatabaseParameters.AttachmentSyncDirection Property
Hope that helps.
Nagma
YifanLiu
New Contributor II
Thanks for the reply Nagma. I am developing for Android and the API is different from WPF. So, unfortunately, your suggestion would not work. Still appreciate it!
JenniferNery
YifanLiu
New Contributor II
Hi Jennifer,
What I was missing is in this line:
I put "image/" instead of "image/png", which is what breaks things.
Thank you!
Best,
Yifan
