100.2.1 Application crash hiding and showing map
5461
18
03-28-2018 07:48 AM
ChrisSmith12
I'm getting an application crash using 100.2.1 .Net in my WPF application. I have the map in a Telerik RadPane.
The crash occurs when I cover/hide the map within my application and then uncover/show it. The crash happens every time on the first two test systems below but I cannot reproduce the crash on the third system. While I am unable to reproduce the crash on the third system, I am able to get the map into a state where it is continually updating but does not show anything.
Test Systems
1. Windows 10 x64 on Dell laptop
2. Windows 10 x64 virtual machine running in VMWare Fusion on Mac OS 10.13.3 host system.
3. Windows 7 x64 on white box laptop
Exception:
Unhandled exception at 0x00007FFBB72D4008 in OperatorConsole.exe: Microsoft C++ exception: Esri_runtimecore::Runtimecore_net::Dx_exception at memory location 0x000000AF882BC160. occurred
AaronMurphy3
After further testing I can confirm this bug was introduced in v100.2. I have tried all the recent versions and v100.1 appears to works fine.
dotMorten_esri
Esri Notable Contributor
Can you go into the project settings and turn on native debugging in the debug tab, then try and reproduce the crash. That should give you a more detailed stack trace that I'd like to see. Also when you hit the crash and Visual Studio breaks, you can go to "Debug -> Save Dump As..." and save a dump file. If you can share this file (it's rather big) we can look at what really happened internally that could cause the crash.
ChrisSmith12
Exception with stack trace:
Unhandled exception at 0x00007FFFF39D3FB8 in OperatorConsole.exe: Microsoft C++ exception: Esri_runtimecore::Runtimecore_net::Dx_exception at memory location 0x00000018723FECC0. occurred
KernelBase.dll!00007ffff39d3fb8()
vcruntime140.dll!00007ffff0ee46e2()
RuntimeCoreNet.dll!00007fff9eb6d2bc()
RuntimeCoreNet.dll!00007fff9eb6d281()
RuntimeCoreNet.dll!00007fff9eb6d3e4()
RuntimeCoreNet.dll!00007fff9ebd0b22()
RuntimeCoreNet.dll!00007fff9ebd016c()
RuntimeCoreNet.dll!00007fff9ebcf26f()
RuntimeCoreNet.dll!00007fff9f415bf5()
RuntimeCoreNet.dll!00007fff9f80c5be()
RuntimeCoreNet.dll!00007fffa03e2c7a()
RuntimeCoreNet.dll!00007fffa03e9062()
RuntimeCoreNet.dll!00007fffa04cd524()
RuntimeCoreNet.dll!00007fff9eefe9ea()
RuntimeCoreNet.dll!00007fff9eeff296()
RuntimeCoreNet.dll!00007fff9ebd0e59()
ucrtbase.dll!00007ffff383d885()
kernel32.dll!00007ffff5a41fe4()
ntdll.dll!00007ffff687ef91()
Dump file sent in email.
AaronMurphy3
I have this same issue I think when I show and hide maps within tab items. Please see my question: https://community.esri.com/message/760175-re-kernelbasedll-exception-occasionally-thrown-since-upgra...
ChrisSmith12
Aaron,
  Was there a resolution or workaround in your case?
JayGilbreath
I'm having the exact same issue.  Any resolution?
ChrisSmith12
Nothing yet.
AaronMurphy3
I have sent a detailed email to one of the Esri team with a sample solution that generates this exception. I also included a video showing how to produce it.
I was only able to get it to blow up if I had a graphic on the map. Did you lot have graphics too? What layers are you using too?
JayGilbreath
Base Map is Bing Hybrid. But it crashes using any base layer.
Sub Layers are:
mPlssLayer = await LayerLoad("https://gis.blm.gov/arcgis/rest/services/Cadastral/BLM_Natl_PLSS_CadNSDI/MapServer");
mTxSurveyLayer = await LayerLoad("https://gis.utlands.utsystem.edu/ags/rest/services/TXSurvey/MapServer");
mTxBlocksLayer = await LayerLoad("https://gis.utlands.utsystem.edu/ags/rest/services/UTLandsBlkSecMap/MapServer");
mCounties = await LayerLoad("https://services.nationalmap.gov/arcgis/rest/services/govunits/MapServer");
I don’t have do anything but load the app and change the Tab page a few times.
Error:
Exception thrown at 0x7734CBB2 in TGSWorkshop2.exe: Microsoft C++ exception: comerror at memory location 0x2557EF2C.
Jay Gilbreath
dotMorten_esri
Could you try and set the RenderingMode property on the graphics overlay to 'Static' and see if it still reproduces?
As I haven't gotten any reproducers from most of your, I'd have to guess a little.
I seem to only be able to reproduce a crash if I have graphics rendering that using dynamic rendering. Whether it's the exact same crash is had to say. Reproducer sample and / or dump files would be extremely helpful 🙂
