Problems in creating executable jar file
2284
12-04-2019 05:03 AM
ArchanaVenkataraman
I can't able to run my simple map application as executable jar file. When i try to run the jar file in command prompt, it shows error like "could not find or load main class" but when creating the jar file i included main class in it.  what could be the problem? This happens when using java 12.
When using java 11, I can't able to create  executable jar. Eclipse doesn't show any main class to choose.
MarkBaird
I've not used Eclipse for many years (prefer IJ Idea) but I would start by taking a look at one of our sample apps.  This is a good basic one to get going with:
arcgis-runtime-samples-java/map/display-map at master · Esri/arcgis-runtime-samples-java · GitHub
You will see the structure of the app contains a launcher class which is needed for JavaFX 11 apps to work in a runnable jar.
If you use gradle, then run the jar task which will build you a runnable jar.  In the project above this will appear in the build/libs directory.
Remember that when you deploy, you will need the native libraries next to the jar.
This doc explains the structure above: Deploy your app—ArcGIS Runtime SDK for Java | ArcGIS for Developers
Depending on how your machine is set up you can double click on the jar or just do a 'java -jar' from the command line.
Does this help?
ArchanaVenkataraman
Thank you for your suggestion Mark Baird. But while running  the jar file, still I got error like this,
MarkBaird
How are you building the jar.  Are you using Eclipse or are you running a gradle script?
Are you starting you app by calling the wrapper/launcher class as we have in the example app:arcgis-runtime-samples-java/DisplayMapLauncher.java at master · Esri/arcgis-runtime-samples-java · G...  ?
This needs to be what you reference in the manifest in the jar file.  In my manifast.mf file I have the following entry:
Manifest-Version: 1.0
Main-Class: com.esri.samples.display_map.DisplayMapLauncher
