Eclipse View for add-in not there. (Mars, SDK 10.2.4)
4440
8
04-20-2016 02:17 AM
BernhardSnizek
I am trying to write a simple Dockable Window in JAVA.
I am following this recipe: ArcObjects 10 Java SDK Help
I have installed ArcMap 10.4, ArcGIS SDK 10.2.4 and Eclipse IDE for JAVA Developers Mars 2.
I have installed the eclipse tools from: C:/Program Files (x86)/ArcGIS SDKs/java10.2.4/sdk/Eclipse Plugin/
I can add a ArcGIS Runtime Java Application but cannot find the add-in View.
Do I need a different SDK ?
All the best
/Bernhard
Tags (3)
EricBader
Hello Bernhard,
It looks like you're mixing 2 different Java SDK products: ArcObjects and Runtime. An easy trap to fall into, unfortunately.
ArcObjects is what is used to create Add-ins for ArcMap. So you were on the right track there. Do not use the Runtime Eclipse plugin for this. There is an Eclipse plugin for ArcObjects in C:\Program Files (x86)\ArcGIS\DeveloperKit10.4\java\tools\eclipse_plugin. For Dockable window and Add-ins, you'll need to use this one.
Make sense?
BernhardSnizek
Hi Eric !
Thanx - sounds good.
Do you have an idea where I can find the ArcObjects JAVA thing - the ESRI site is a maze !
Best regards
/B
EricBader
Agreed. Quite maze.
Here is the link to the doc: ArcObjects Help for Java developers | ArcGIS for Desktop
You already have the software, correct?
BernhardSnizek
I have ArcMap, ArcGIS Pro but not yet ArcObjects. Therefore no folder DeveloperKit either  ...
EricBader
You can get it via your EDN subscription...do you have one?
https://my.esri.com/
BernhardSnizek
No not yet. The link sends me to a page where I have to ask my own company for permission grrr...
BernhardSnizek
Maybe I should ask you a little question about my approach.
Maybe its better to use .net C# ?
We want to implement a JavaScript component (a search gadget) into ArcMap. It searches in a series of national data sources and returns a JSON with a very simple geometry.
It would be optimal if we could use some kind of a HTML/JS container inside the add-in.
Would you recommend .net or JAVA for that ?
Thanx and all the best
/Bernhard
EricBader
Well, the future of Desktop add-ins will be .NET, so your hunch is probably a good one.
All the best!
Eric
