Is it possible to use this jar for both deployment scenarios along with one deployment of the runtime? Or would we need to create two separate jar's and runtime deployments to get this to work?
It seems that I cannot open a .mpk with a basic license is this correct?
Hi Mark,
I have the same problem, I want to load information(just for read, not for edition), I'm trying to use standard license, but if it easier using that kind of functionality please tell me how to do it, now I'm using a TPK(fro base map) and MPK for my info, I can identify on click or mouse over, is it possible to do it using "the new geodatabase format"?
Hi Mike,
I'm a bit intrigued by this "new geodatabase format" that allows you to render its containing data using a basic license so long as it's read-only. Up to this point, I've had to use a standard deployment license just to render rasters off mosaic datasets from a geodatabase unto the map, with no editing capability, because of merely using the LocalServer class. Has this changed? I am interested in getting more information on this.
Carlos
