public class ResetMapApplication { /** * Layer initialize complete listener */ public class LayerListener implements LayerInitializeCompleteListener { @Override public void layerInitializeComplete(LayerInitializeCompleteEvent e) { Layer layer = e.getLayer(); if (layer.getStatus() == LayerStatus.INITIALIZED) { System.out.println(String.format("-LayerInitializeCompleteEvent- Layer '%s' is initialized on map '%s' !", layer.getName(), map.getName())); } else { System.out.println(String.format("-LayerInitializeCompleteEvent- ERROR: Layer '%s' is NOT initialized on map '%s' !", layer.getName(), map.getName())); System.out.println(" initialization error: " + e.getLayer().getInitializationError()); } } } /** * Map event listener */ public class MapListener implements MapEventListener { @Override public void mapDispose(MapEvent event) { System.out.println(String.format("-MapEventListener- Map '%s' is disposed !", map.getName())); } @Override public void mapReady(final MapEvent event) { SwingUtilities.invokeLater(new Runnable() { @Override public void run() { System.out.println(String.format("-MapEventListener- Map '%s' is ready !", map.getName())); } }); } @Override public void mapExtentChanged(MapEvent event) { // do nothing } } /** * Main : application's entry * @param args */ public static void main(String[] args) { SwingUtilities.invokeLater(new Runnable() { public void run() { try { // instance of this application ResetMapApplication layerApp = new ResetMapApplication(); // create the UI, including the map, for the application. JFrame appWindow = layerApp.createWindow(); appWindow.add(layerApp.createUI()); appWindow.setVisible(true); } catch (Exception e) { // on any error, display the stack trace. e.printStackTrace(); } } }); } // content pane private JLayeredPane contentPane; // map private JMap map; // map count private int count = 1; // base layer TILED PACKAGE 1 private static final String TPK_BASEMAP_1 = "C:\\temp\\Topographic.tpk"; // base layer TILED PACKAGE 2 private static final String TPK_BASEMAP_2 = "C:\\temp\\SanFrancisco.tpk"; /** * Creates a window. * @return a window. */ private JFrame createWindow() { JFrame window = new JFrame("Test - Reset a Map"); window.setBounds(100, 100, 1000, 700); window.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE); window.getContentPane().setLayout(new BorderLayout(0, 0)); window.addWindowListener(new WindowAdapter() { @Override public void windowClosing(WindowEvent windowEvent) { super.windowClosing(windowEvent); if (map != null) { map.dispose(); } } }); return window; } /** * Creates application content with ToolBar and Map's container * @return */ private JComponent createUI() { // application content JPanel applicationPanel = new JPanel(); applicationPanel.setLayout(new BorderLayout(0, 0)); // button toolbar final JToolBar toolBar = this.createToolBar(); // panel for the map : map will be created later... this.contentPane = this.createContentPane(); applicationPanel.add(toolBar, BorderLayout.NORTH); applicationPanel.add(this.contentPane, BorderLayout.CENTER); return applicationPanel; } /** * Create a toolbar with buttons * @return toolBar - the toolBar */ private JToolBar createToolBar() { JToolBar toolBar = new JToolBar(); toolBar.setLayout(new FlowLayout(FlowLayout.CENTER)); // button add TPK 1 JButton buttonTPK1 = new JButton("Add TPK Topographic"); buttonTPK1.addActionListener(new ActionListener() { public void actionPerformed(ActionEvent e) { // reset the map resetMap(); // add tiled layer ArcGISLocalTiledLayer tiledLayer = new ArcGISLocalTiledLayer(TPK_BASEMAP_1); tiledLayer.setName(TPK_BASEMAP_1); tiledLayer.addLayerInitializeCompleteListener(new LayerListener()); map.getLayers().add(tiledLayer); } }); toolBar.add(buttonTPK1); // button Add TPK 2 JButton buttonTPK2 = new JButton("Add TPK SanFrancisco"); buttonTPK2.addActionListener(new ActionListener() { public void actionPerformed(ActionEvent e) { // reset the map resetMap(); // add tiled layer ArcGISLocalTiledLayer tiledLayer = new ArcGISLocalTiledLayer(TPK_BASEMAP_2); tiledLayer.setName(TPK_BASEMAP_2); tiledLayer.addLayerInitializeCompleteListener(new LayerListener()); map.getLayers().add(tiledLayer); } }); toolBar.add(buttonTPK2); return toolBar; } /** * Creates a content pane. * @return a content pane. */ private JLayeredPane createContentPane() { JLayeredPane contentPane = new JLayeredPane(); contentPane.setLayout(new BorderLayout(0, 0)); contentPane.setVisible(true); return contentPane; } /** * Reset the map : * - remove and dispose resources * - create new map * - remove and add on panel (container) */ private void resetMap() { System.out.println("-actionPerformed - RESET MAP !"); if (map != null) { // remove all layers for (int i = (this.map.getLayers().size() - 1) ; i == 0 ; i--) { this.map.getLayers().remove(i); } // dispose data ressources this.map.dispose(); // =>> ISSUE HERE : dispose() seems to be fired on the new map after createMap() below (see Console prints) // remove map from content pane this.contentPane.remove(map); } // re-create the map this.map = createMap(); // =>> ISSUE HERE : can I avoid a new JMap to re-initialize the map (no spatial ref, no fullextent, etc.) ?? // add new map to the content pane this.contentPane.add(map); // Revalidate the map to perform a hierarchical refresh of all components this.map.revalidate(); } /** * Create a map with navigator overlay * @return JMap - the map */ private JMap createMap() { JMap jMap = new JMap(); // give an incremental name jMap.setName("map " + count ++); // Add map event listner jMap.addMapEventListener(new MapListener()); // Add NavigatorOverlay NavigatorOverlay navigator = new NavigatorOverlay(); jMap.addMapOverlay(navigator); return jMap; } }
If you change your dispose event handler to use the map reference from the event you will get the correct output
Hy Gayle,
What is the status regarding a 'reset' method on the JMap class ?
It's not possible to do this at the moment; there is no 'reset' method on the JMap class. It's something we are considering for a future release.
