10.2 Migration Issue
2737
16
12-09-2013 06:27 AM
StephenBaier
I decided to migrate to 10.2 today, hoping it would be smooth and painless because my application doesn't do anything special - simply renders symbols on a graphics layer.
Note: I can run the sample applications without problems - so either the problem is in my project setup or my data. Would there be any reason a tile package that worked for 10.1.1 not work with 10.2?
This code creates the map, if it is commented out I don't receive be below error spewing, but it still seg-faults upon exiting the application.
ArcGISLocalTiledLayer tiledLayer = new ArcGISLocalTiledLayer("/path/to/map.tpk");
tiledLayer.setName("Nautical Chart");
getLayers().add(tiledLayer);
When I start my application (without the above code commented out), it starts continuously spewing:
Frame_buffer_OGL::init_ FAILED to create_ FramebufferName
When I close the application I get a core dump, regardless of the local tiled layer.
Any helpful hints?
More information:
When the application starts I get this information:
Java version : 1.7.0_25 (Oracle Corporation) amd64
Rendering engine : OpenGL
GLX version 1.4
glxinfo | grep OpenGL
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 640/PCIe/SSE2
OpenGL version string: 4.3.0 NVIDIA 319.49
OpenGL shading language version string: 4.30 NVIDIA via Cg compiler
Core dump that occurs after closing application:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f2ed57f5ea9, pid=8724, tid=139829799008000
# JRE version: 7.0_25-b15
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.25-b01 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# V  [libjvm.so+0x709ea9]  Monitor::ILock(Thread*)+0x79
# Core dump written. Default location: /home/user/core or core.8724
# An error report file with more information is saved as:
# /home/user/hs_err_pid8724.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
CarlosColón-Maldonado
public class MapDisposeApp {
    private JFrame window;
    private JMap map;
    public MapDisposeApp() {
        window = new JFrame();
        window.setSize(800, 600);
        window.setLocationRelativeTo(null); // center on screen
        window.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        window.getContentPane().setLayout(new BorderLayout(0, 0));
        window.addWindowListener(new WindowAdapter() {
            @Override
            public void windowClosing(WindowEvent windowEvent) {
                super.windowClosing(windowEvent);
//                map.dispose();
        map = new JMap();
        window.getContentPane().add(map);
//        ArcGISTiledMapServiceLayer tiledLayer = new ArcGISTiledMapServiceLayer(
//            "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
//        map.getLayers().add(tiledLayer);
     * @param args
    public static void main(String[] args) {
        EventQueue.invokeLater(new Runnable() {
            @Override
            public void run() {
                try {
                    MapDisposeApp application = new MapDisposeApp();
                    application.window.setVisible(true);
                } catch (Exception e) {
                    e.printStackTrace();
Are you getting the spewing-offs mentioned on this thread?
JeremieJoalland1
no sorry, I found nothing related to "Frame_buffer_OGL" in my crach log file.
Thanks, Jeremie. I tried your code is not happening on me, either. It's on my app which uses some AWT components over the map which might be causing the issue.
JohnWass
I ran into the same spewing of messages ('Frame_buffer_OGL::init_ FAILED to create_ FramebufferName') when my migrated app started up.  Things were working fine 15 minutes prior in 10.1.1, but then stopped after swapping the libraries.
In my case I found the remedy was to run the application on the event dispatch thread (ie. SwingUtilities.invokeLater).  I wasnt doing so in 10.1 without issue, but it appears something in 10.2 is more sensitive in that regard.
hth
john
ColinAnderson1
Yes, all use of JMap (including creation and disposing) should be carried out on the EDT. JMap being a Swing component has the same restrictions you would find with the standard Swing components - http://docs.oracle.com/javase/7/docs/api/javax/swing/package-summary.html#threading
This was also a restriction for the previous release but it might have been a bit more robust to people not following the EDT requirement.
StephenBaier
John - Thanks for the information. I no longer need to use my workaround by opening my map on the Swing EDT.
Colin - Thanks for the additional information. Not disposing on the EDT was causing problems after creating on the EDT.
Thank you, John. I got it to work as well.
