Show KML on the Map
2799
10-28-2014 01:12 PM
New Contributor II
I need to load KML file to Map, is it supported in current SDK?
If so, is there any example?
Alex
Tags (1)
Reply
Esri Frequent Contributor
Good news! KML is now supported (starting with the v100.4 release in Q4 2018). In the recent v100.5 release we enhanced KML by adding support for Tours. And we're currently working on some more really exciting KML enhancements!
Cheers
Mike
Reply
KML is not currently supported on the ArcGIS Runtime SDK 10.2.4 for iOS.  We have a requirement to add it for a future implementation to support that native format. We won't have anything until next year.
In the mean time, you can upload the KML file to ArcGIS.com and consume the service with the Runtime iOS SDK, or if you have server, you can create a service from a KML file.
Hope this helps
Cheers
Al
Use local Geodatabase
Reply
Cheers
Mike
Reply
