Apr 13 09:58:46 MBP Installer[476]: @(#)PROGRAM:Install PROJECT:Install-580
Apr 13 09:58:46 MBP Installer[476]: @(#)PROGRAM:Installer PROJECT:Installer-430.1
Apr 13 09:58:46 MBP Installer[476]: Hardware: MacBookPro5,1 @ 2.66 GHz (x 2), 4096 MB RAM
Apr 13 09:58:46 MBP Installer[476]: Running OS Build: Mac OS X 10.6.3 (10D573)
Apr 13 09:58:46 MBP Installer[476]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Apr 13 09:58:46 MBP Installer[476]: Env: TMPDIR=/var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-/
Apr 13 09:58:46 MBP Installer[476]: Env: SHELL=/bin/bash
Apr 13 09:58:46 MBP Installer[476]: Env: HOME=/Users/kmonroe
Apr 13 09:58:46 MBP Installer[476]: Env: USER=kmonroe
Apr 13 09:58:46 MBP Installer[476]: Env: LOGNAME=kmonroe
Apr 13 09:58:46 MBP Installer[476]: Env: DISPLAY=/tmp/launch-EyAw8E/org.x:0
Apr 13 09:58:46 MBP Installer[476]: Env: SSH_AUTH_SOCK=/tmp/launch-4u97UD/Listeners
Apr 13 09:58:46 MBP Installer[476]: Env: Apple_PubSub_Socket_Render=/tmp/launch-l8gUzy/Render
Apr 13 09:58:46 MBP Installer[476]: Env: __CF_USER_TEXT_ENCODING=0x1F5:0:0
Apr 13 09:58:46 MBP Installer[476]: Env: COMMAND_MODE=unix2003
Apr 13 09:58:46 MBP Installer[476]: AGSiPhoneSDK_03122010 Installation Log
Apr 13 09:58:46 MBP Installer[476]: Opened from: /Users/kmonroe/Downloads/AGSiPhoneSDK.pkg
Apr 13 09:59:00 MBP Installer[476]: ================================================================================
Apr 13 09:59:00 MBP Installer[476]: User picked Standard Install
Apr 13 09:59:00 MBP Installer[476]: Choices selected for installation:
Apr 13 09:59:00 MBP Installer[476]: Upgrade: "AGSiPhoneSDK_03122010"
Apr 13 09:59:00 MBP Installer[476]: Upgrade: "SDK"
Apr 13 09:59:00 MBP Installer[476]: AGSiPhoneSDK.pkg#packageroot.pkg : com.esri.arcgisiphonesdk.pkg : 1
Apr 13 09:59:00 MBP Installer[476]: It took 0.00 seconds to summarize the package selections.
Apr 13 09:59:00 MBP Installer[476]: -[IFDInstallController(Private) _buildInstallPlan]: location = file://localhost
Apr 13 09:59:00 MBP Installer[476]: -[IFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/kmonroe/Downloads/AGSiPhoneSDK.pkg#packageroot.pkg
Apr 13 09:59:00 MBP Installer[476]: Will use PK session
Apr 13 09:59:00 MBP Installer[476]: Starting installation:
Apr 13 09:59:00 MBP Installer[476]: Configuring volume "Macintosh HD"
Apr 13 09:59:00 MBP Installer[476]: Preparing disk for local booted install.
Apr 13 09:59:00 MBP Installer[476]: Free space on "Macintosh HD": 174.76 GB (174757707776 bytes).
Apr 13 09:59:00 MBP Installer[476]: Create temporary directory "/var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-//Install.476GUGGcd"
Apr 13 09:59:00 MBP Installer[476]: IFPKInstallElement (1 packages)
Apr 13 09:59:00 MBP installd[481]: PackageKit: ----- Begin install -----
Apr 13 09:59:00 MBP installd[481]: PackageKit: request=PKInstallRequest <1 packages, destination=/Users/kmonroe>
Apr 13 09:59:00 MBP installd[481]: PackageKit: packages=(\n "PKLeopardPackage <file://localhost/Users/kmonroe/Downloads/AGSiPhoneSDK.pkg#packageroot.pkg>"\n)
Apr 13 09:59:00 MBP installd[481]: PackageKit: Extracting /Users/kmonroe/Downloads/AGSiPhoneSDK.pkg (destination=/var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-/PKInstallSandbox-tmp/Root, uid=501)
Apr 13 09:59:01 MBP installd[481]: PackageKit: Executing script "./preinstall" in /private/tmp/PKInstallSandbox.c5fnlo/Scripts/com.esri.arcgisiphonesdk.pkg.oCyQPd
Apr 13 09:59:01 MBP installd[481]: ./preinstall: This is the preflight
Apr 13 09:59:01 MBP installd[481]: PackageKit: Shoving /var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-/PKInstallSandbox-tmp/Root (1 items) to /Users/kmonroe
Apr 13 09:59:01 MBP /System/Library/PrivateFrameworks/PackageKit.framework/Resources/shove[483]: [source=file] failed _RelinkFile(/var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-/PKInstallSandbox-tmp/Root/Library/SDKs/Samples/MapViewDemo/Classes/MapViewDemoViewController.m, /Users/kmonroe/Library/SDKs/Samples/MapViewDemo/Classes/MapViewDemoViewController.m): Operation not permitted
Apr 13 09:59:01 MBP installd[481]: PackageKit: Install Failed: (null)\nError Domain=PKInstallErrorDomain Code=120 UserInfo=0x100310b40 "An unexpected error occurred while moving files to the final destination." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=1 "The operation couldn�??t be completed. Operation not permitted") {\n NSLocalizedDescription = "An unexpected error occurred while moving files to the final destination.";\n NSUnderlyingError = "Error Domain=NSPOSIXErrorDomain Code=1 \"The operation couldn\U2019t be completed. Operation not permitted\"";\n arguments = (\n "-f",\n "-s",\n "/var/folders/XS/XStbXdJHFWO9xTD+2gBHUE+++TI/-Tmp-/PKInstallSandbox-tmp/Root",\n "/Users/kmonroe"\n );\n}
Apr 13 09:59:01 MBP Installer[476]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=120 UserInfo=0x100187120 "An unexpected error occurred while moving files to the final destination." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=1 "The operation couldn�??t be completed. Operation not permitted")
Apr 13 09:59:01 MBP Installer[476]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Apr 13 09:59:01 MBP Installer[476]: IFDInstallController 14FAE0 state = 7
Apr 13 09:59:01 MBP Installer[476]: Displaying 'Install Failed' UI.
Apr 13 09:59:01 MBP Installer[476]: 'Install Failed' UI displayed message:'The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.'.
