Does the AGSTextSymbol support the text template any more?
2324
09-09-2014 07:36 PM
lynnwang
New Contributor II
Earlier version of SDK can set the text content fromw values from the graphic's attributes like below:
AGSTextSymbol *textSymbol = [AGSTextSymbol textSymbolWithTextTemplate:@"${pointID}" color:[UIColor redColor]];
How to do this in recent version?
YueWu1
by Esri Regular Contributor
Hello Lynn,
I think the method still using in 10.2.3. Please check this online documentation:10.2.3: AGSTextSymbol Class Reference
Hope this help.
lynnwang
New Contributor II
Hi, Yue!
      I red a document before. It saids the porperty 'text' will replace the porerty 'text template' after v10.2.2.
      I tried 'text' porperty with the token like ${pointID}. But it doesn't work.
      Did you test this function before? ??
       Does it works?
       If so , please show me some codes.
      Thanks.
YueWu1
Hi Lynn,
I am not really sure what is ${pointID}? Is it point to your database field or something else?
Here are two snippet code to use this AGSTextSymbol textSymbolWith Text method:
NSString *stopString = @"";
  if (stopNumber != NSNotFound) {
  stopString = [NSString stringWithFormat:@"%d", stopNumber];
  AGSTextSymbol *ts = [AGSTextSymbol textSymbolWithText:stopString color:[UIColor blackColor]];
Or
NSMutableString *word = [NSMutableString stringWithFormat:@"Hello world"];
AGSTextSymbol *txtSymbol = [AgSTextSymbol textSymbolWithText:word color:[UIColor redColor]];
lynnwang
New Contributor II
Hi, Yue
     Yes, the pointID is a field name of a graphic. In the old version of iOS SDK, I can use the property ‘textTemplate’ to set the text symbol text content of a graphic using its attribute field name but not a very string (just like your codes above). That will be very convenient.  This function is very similar with the AGSCalloutTemplate 's titleTemplate.
   I just like to know wether the AGSTextSymbol still supports this kind of template function.
