ArcGIS Classes not showing up (ie AGSMapView)
705
06-19-2012 02:14 PM
JeffGiesler
Hello Everyone,
I am completely new at IOS development so I apologize if this is a little basic.  I am currently trying to build a simple app just to get familiar with the runtime.  I follow the configuring xcode steps to the letter but my ArcGIS.bundle doesn't seem to load correctly.  When open the project it looks like a folder piece of paper where it (I assume) should look red.  If I open a sample project everything is fine but if I remove the bundle and try to reload I get the same problem.  I am not sure what I am doing wrong.  Any help would be greatly appreciated.
Cheers,
Jeff
JeffGiesler
Rick,
Again thanks for your help I have changed the header path.  I actually figured out what my problem was late alst night.  I hadn't put the import <ArcGIS/ArcGIS.h> in the correct place.  It fixed being able to see the ArcGIS classes.  I still don't know why they don't look the same but as long as the functionality is there I don't care.  Again thanks for your help and pointing me in the right direction.
Cheers,
Jeff
RickJones
Occasional Contributor II
In the  Finder, click Go.
Click Library. If Library is hidden, hold the Option key.
Navigate to SDKs->ArcGIS->ArcGIS.Framework->Versions->Current->Resources
Add that ArcGIS.bundle to the project.
You may need to change the Xcode settings to use the Current->headers folder there.
JeffGiesler
Rick,
I did the first part as you suggested. I had done so while creating the project but figured I would try again anyway. Nothing has changed. I am not sure how to change the headers as you point out in the second part. I have attached screen shots of what the bundles look like in both the sample and my project. For some reason it looks like my project is treating the bundle as a folder while the sample is not. I have no clue what is going on.
Cheers,
Jeff
RickJones
To change the headers setting,
In Build Settings, User Header Search Paths:
${HOME}/Library/SDKs/ArcGIS/ArcGIS.Framework/Versions/Current/Headers
I'm not sure why your bundle isn't expanding.
You could try copying the bundle to your project folder, and including it to test.
JeffGiesler
Rick,
Cheers,
Jeff
