Apple Mach-O Linker (Id) Error's
2395
5
12-13-2011 01:31 AM
DanielGranger
Hi all,
Just installed ArcGIS for iOS API and go to run the MapViewDemo example and I get 4 fatal errors:
Undefined symbols for architecture i386:
  "_OBJC_CLASS_$_AGSTiledMapServiceLayer", referenced from:
      objc-class-ref in MapViewDemoViewController.o
  "_OBJC_CLASS_$_AGSDynamicMapServiceLayer", referenced from:
  "_OBJC_CLASS_$_AGSSpatialReference", referenced from:
  "_OBJC_CLASS_$_AGSEnvelope", referenced from:
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Any Ideas?
RickJones
Occasional Contributor II
Try removing the libArcGIS.a from the project, and re-adding it.
PrasadJ
Thank You once it remove and add it working fine. The application was build fine But I am not getting map on the simulator.
NimeshJarecha
Is your AGSMapView outlet is connected to "Map View"?
Reagards,
Nimesh
PrasadJ
Ya i have done.
Steps I have done:
1) Open xib file
2) Right Click on File'Owner and drag to View then it found View. I select View
3) Again Right Click on File Owner and Drag till Map View then i found mapView. I select MapView
I am new this development. so, Please provide the steps if any thing wrong.
NimeshJarecha
Here are the detail steps to Configuring an Xcode Project..
Hope this helps!
Regards,
Nimesh
