wrapAround doesn't work with tiled service in iOS, works in other API's
3085
11
05-17-2012 11:57 AM
LukePhilips
Hey,
I've got a tiled map service that is Web Mercator (WKID 102100), I have no problem using it in the other client API's (e.g. JavaScript) with wrapAround however when I add it to a iOS mapView the wrap around no longer works. any recommended means of debugging this?
LukePhilips
See attached, I've removed the layers in the arrays to make this more reasonable.
NimeshJarecha
Thanks for the file. You can see that the full extent of your tiled layer is...
Full Extent:
XMin: -20036554.6687116
YMin: -30240971.9583863
XMax: 20037164.0316042
YMax: 30240971.9583862
Spatial Reference: 102100 (3857)
The full extent of the ESRI web mercator map is...
Full Extent:
XMin: -20037507.0671618
YMin: -19971868.8804086
XMax: 20037507.0671618
YMax: 19971868.8804086
This is the reason why wrap around is not working for your layer. Please correct that and it should work!
Regards,
Nimesh
