When trying to Navigate to a point I receive a ARCGis runtime error
1661
01-25-2023 12:18 PM
CarlosHenderson
ArcGIS Runtime Error Occurred. Set a breakpoint on C++ exceptions to see the original callstack and context for this error:  Error Domain=com.esri.arcgis.runtime.error Code=15 "Invalid call."
My code:
public func startRoute(to destination: AGSPoint) {
        queue.async { [weak self] in
            guard let self = self else {
                Logger.log(error: nil)
                return
            // set destination and start locations
            self.destinationLocation = destination
            self.startLocation = AGSPoint(clLocationCoordinate2D: self.positionManager.current.toCLLocation().coordinate)
            self.routeTask = AGSRouteTask(databaseName: "", networkName: "")
            self.routeTask.defaultRouteParameters { [weak self] (params: AGSRouteParameters?, error: Error?) in
                    return
                if let params = params {
                    params.returnDirections = true
                    params.returnStops = true
                    params.returnRoutes = true
                    params.outputSpatialReference = .wgs84()
                    params.setStops(self.makeStops())
                    self.routeParameters = params
                    // calculate route
                    self.routeTask.solveRoute(with: params) { [weak self] result, error in
                        guard let self = self else { return }
                        if let result = result {
                            // success
                            self.didSolveRoute(with: .success(result))
                        } else if let error = error {
                            // failure
                            self.didSolveRoute(with: .failure(error))
                    guard let del = self.delegateelse { return }
                    del.updateNavigationView(direction: "Error \((error as NSError).code)", directions: [AGSDirectionManeuver]())
                    Logger.routing.error("Failed to get route parameters with error \(error.localizedDescription, privacy: .public)")
func startEsriNavigation(to point: AGSPoint) {
        guard let positionManager = positionManagerelse {
            return
        routeService = RMRouteService(positionManager: positionManager)
        routeService.delegate = self
        routeService.startRoute(to: point)
        mapToolsView.navigationPoint = point
        isRouting = true
        self.toggleMapTools(toolIndex: 1)
        DispatchQueue.main.async { [weak self] in
            self?.esriMap.locationDisplay.start()
            self?.navigationButton.isHidden = false
Ting
by Esri Regular Contributor
Hi Carlos,
Can you provide a minimum reproducible example for your error? Also, you may take a look at the example code for navigation in the samples app.
From the code you provide, I can see some issues that might contribute to an error, though am not sure which is yours
- The route task is created with an invalid database
- The result of route solving is not used
- No license key or API key is explicitly set to use the routing functionalities
CarlosHenderson
I removed the database and network names. Not sure if it's sensitive information or not. That data is valid.
I looked at your example, how should I use didSolveRoute?
Can you send some examples on how and where to set the license or api key?
is it different from the esri sdk license that I set on application start up?
Ting
If you have set a global key on the AGSArcGISRuntimeEnvironment, then you should be good.
didSolveRoute in that sample is just a helper method to handle the AGSRouteResult. From there you can create an AGSRouteTracker with the result, and then have the location display (blue dot) to snap to the route. I would encourage you to download the samples app and run it locally, play with it a bit and set breakpoints at where your error happens to see what is the cause.
There is another guide on the developer website that breaks down each step to configure the route tracker.
Can you let me know which line in your code gives the error? A minimum repro app would be the best. You can also first try with Esri's World Route API in the AGSRouteTask to ensure it is not a data problem.
CarlosHenderson
Thank you for the documentation.
When I add break points it doesn't hit
if let params.
Im not sure, I'm receiving an error code 24. Object is already owned
Ting
There are too much going on in your code, thus it is hard to tell the real problem. Try to strip down anything unrelated first. I'd suggest starting clean from sth like this
import UIKit
import ArcGIS
class ViewController: UIViewController {
    @IBOutlet var mapView: AGSMapView! {
        didSet {
            let map = AGSMap(basemapStyle: .arcGISLightGray)
            mapView.map = map
    let stops: [AGSStop] = {
        let stop1 = AGSStop(point: AGSPoint(x: -117.160386727, y: 32.706608, spatialReference: .wgs84()))
        stop1.name = "San Diego Convention Center"
        let stop2 = AGSStop(point: AGSPoint(x: -117.173034, y: 32.712329, spatialReference: .wgs84()))
        stop2.name = "USS San Diego Memorial"
        let stop3 = AGSStop(point: AGSPoint(x: -117.147230, y: 32.730467, spatialReference: .wgs84()))
        stop3.name = "RH Fleet Aerospace Museum"
        return [stop1, stop2, stop3]
    /// The route task to solve the route between stops, using the online routing service.
    let routeTask = AGSRouteTask(url: URL(string: "https://route-api.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World")!)
    func solveRoute(routeTask: AGSRouteTask) {
                // Explicitly set values for parameters.
                params.setStops(self.stops)
                self.routeTask.solveRoute(with: params) { (result: AGSRouteResult?, error: Error?) in
                        print(result.routes.first!.directionManeuvers.map(\.directionText).joined(separator: "\n"))
                        print(error.localizedDescription)
    override func viewDidLoad() {
        super.viewDidLoad()
        solveRoute(routeTask: routeTask)
The workflow is pretty intuitive:
1. Create a route task. Either from a network database or from the Esri online route service.
2. Create the route parameters. If succeeds, the closure will call back the routing parameters.
3. Solve the route with the parameters. The closure will call back a route result or an error.
Again, it would be great if you can create a minimal repro case based on the snippet above. It will help us to find the issue. 🙂
