iOS 5.0 Bug after installing the new SDK 10.1 in Project
511
02-18-2013 01:52 PM
GregHawk
When using the newest API for iOS 10.1.1 in my application and XCode for ios 6 the build has an issue when running on ios 5.0 even though this is the lowest version to be supported via the release notes.  I do not see the problem in 5.1+.  On the crash reports it is erring on setting the Units property of the AGSMapServiceInfo class.  This is happening within the framework and outside my control.
-[AGSMapServiceInfo setUnits:] (in MyApp) (AGSMapServiceInfo.m:53)
Any ideas people?  This method should be fine.
DiveshGoyal
Can you post the code to help us reproduce this problem?
Also, do you see the error in the simulator too? or only on the device?
