How to show simple GeoJson on the map?
1357
07-11-2023 12:35 AM
JulianBissekkou
Hello everybody,
I have a simple Geojson that I want to display on my map. I parsing the json using
`AGSFeatureCollection.fromJSON()` and then adding a `AGSFeatureCollectionLayer(featureCollection: collection)` to the map using `mapView.map!.operationalLayers.add(layer)`
This shows nothing and I think it fails at the first step where I parse it into a FeatureCollection because `unknownJSON` contains all the data.
Am I using an unsupported format or is something missing?
Thanks in advance.
Example json:
"features": [
"geometry": {
"type": "LineString",
"coordinates": [
6.123123123,
52.8912817381
6.123141241,
52.12313122
"type": "Feature",
"properties": {
"oid": 9
"geometry": {
"coordinates": [
13.11,
50.15
12.214123,
48.12312
"type": "Feature",
"properties": {
"oid": 5
"geometry": {
"coordinates": [
9.231231,
52.1231312
9.123123,
52.123131
"type": "Feature",
"properties": {
"oid": 4
"type": "FeatureCollection"
Ting
by Esri Contributor
Hi Julian, unfortunately Runtime iOS SDK doesn't fully support GeoJSON, unlike the GeoJSONLayer API in Javascript. 🙁 Runtime does support very simple GeoJSON such as creating a geometry, but not much else. There are a few options:
1. Publish the GeoJSON file to ArcGIS Online and consume it as a feature layer. See the doc here.
2. Break the feature collection into separate geometries manually.
3. Use tools to convert it to other formats that Runtime supports.
Ting
by Esri Contributor
p.s., here is an answer from my colleague Nick that may help you: https://community.esri.com/t5/arcgis-runtime-sdk-for-ios-questions/polygons-as-feature-layer/m-p/127...
