GIS crashed with IOS SDK 10.1.1-u2, iOS 8.1.1
4276
12-16-2014 10:04 AM
GajaNaik
New Contributor III
Hello,
we are using AGS-IOS 10.1.1, with Server side version is 10.22.
when iPad updated with latest IOS 8.1.1/8.1.2 GIS got crashed where deployment target is IOS 6.1. (work if deployment target is 8.1.1/8.1.2)
server side GIS version is 10.22.
Crashed with Esri-runtime Geometry exception,  it works on IOS 8.1.1 and not on IOS 6.
Thanks
BobWaltrip
Hi, I moved your question to this space.  The My Esri group is for discussion around the My Esri web site.
Bob
MichaelDavis3
Occasional Contributor III
The ios 7 & 8 updates introduced changes to the way views address each other.  You need to reset your development target in XCode and debug the new errors that pop up.
GajaNaik
New Contributor III
i can not change deployment target as of now. but with same setting it work perfectly fine if Server side GIS version is 10.0.4, it only crash to another server having version 10.2.2.  below mentioned error :
libc++abi.dylib: terminating with uncaught exception of type Esri_runtimecore::Geometry::Geometry_exception: std::exception
it crash only n only if Server side GIS version is 10.2.2
