I am trying to find the estimated size of AGSGeodatabaseSycnTask. There is AGSExportTileCacheTask i.e. estimateTileCacheSizeJob that will send the job size but that is for TileCache. I could not find anything related to geodatabase sync task. Is is not supported?
You are correct. At this point estimating the size of a geodatabase downloaded from the AGSGeodatabaseSyncTask is not supported.
