ArcGis locator task vs REST call has different results
1630
08-09-2022 08:34 AM
JulianBissekkou
I am using the android and iOS sdks to perform a geocode request to the server. When I am calling the same endpoint using REST I get different results back.
In my case the REST call has more results.
iOS code:
        let locatorTask = AGSLocatorTask(url: URL(string: "https://my-server/services/GeocodeServer/")!)
        let params = AGSGeocodeParameters()
        params.maxResults = payload.maxSuggestions
        params.countryCode = "DE"
        params.outputSpatialReference = .wgs84()
        params.resultAttributeNames = ["*"]
        locatorTask.geocode(withSearchText: payload.searchQuery, parameters: params) {
          // handle result
REST call:
https://my-server/services/GeocodeServer/suggest?f=json&text=SomeStreet
It would be nice to know what request url the iOS lib generates.
Nicholas-Furness
You can use AGSRequestConfiguration to log some debug info to the console. Try something like this:
if let gc = AGSRequestConfiguration.global().copy() as? AGSRequestConfiguration {
    gc.debugLogRequests = true
    locatorTask.requestConfiguration = gc
That should output the request for you.
Please note that you should not log this debug info in a release version of your app. There is a performance hit to this logging and you should disable it in production and testing.
Nicholas-Furness
JulianBissekkou
Thanks! I was able to take a look at the request and I noticed that the client sdk uses a different query param.
It adds `findAddressCandidates?`, `&outSR`, `&forStorage` and `&SingleLine` but the REST calls works fine with just `&text=`.
I would like to only send `&text` and nothing else.
Are we able to configure that?
JulianBissekkou
Okay I think i missed the "suggest" method of the locatorTask that does exactly what I thought.
My question is: Why is there a "suggest" api when we can also search for points using geocode?
