AGSPortalItem.serviceURL Is Blank
1259
7
06-25-2019 08:48 AM
NickG
Trying to access the info of a feature service portal item via itemID.  I'm able to access other properties like
title but not the serviceURL.  I've tried in both online and on premise but to no avail.  The items are shared with my user via a group.  I've even tried loading the item (portalItem.load) and still the url is empty. Not sure if a bug or I am missing something obvious.  Any help would be greatly appreciated.   Example code below.  Thank you.
func getPortalFeatureServiceItem(){
        guard let portal = self.portal else {
            return
        let portalItem = AGSPortalItem(portal: portal, itemID: "ID")
        if let itemURL = portalItem.serviceURL{
            print(itemURL.absoluteString) -> ""  //itemUrl gets set but is empty
        print("item title \(portalItem.title)") -> "Title"
Nicholas-Furness
You will need to load the portal item. See the Loadable Resources guide.
Try something like this:
portalItem.load { (error) in
    if let error = error {
        print("Error loading portal item: \(error.localizedDescription)")
        return
    print("Service URL: \(portalItem.serviceURL)")
Are you sure you can read the title? In my testing I am unable to read the title until it's loaded.
        return
    print("Title (loaded): \(portalItem.title)")
print("Title (unloaded): \(portalItem.title)")
outputs this…
Title (unloaded):
Title (loaded): Rockingham County Parcels
Notice how the unloaded output prints first. The loaded call requires a round-trip to load the metadata from the portal item.
Hope this helps.
Nick
NickG
I've tried loading the item.  Still no url.  Sorry shouldn't have included the title in the "unloaded" example.
           guard error == nil else { return }
Nicholas-Furness
And it's a service item? E.g. a Feature Service? You won't get a serviceURL if it's, say, a web map. What do you see if you print the typeName?
NickG
As far as I know.  It's got the same title and I've tried the following code in the load block and it reaches the print statements.
            if (portalItem.type == .featureService){
               guard let url = portalItem.serviceURL?.appendingPathComponent("0", isDirectory: false) else {
                         return
                print("feature service") -> "feature service"
                print(url) -> 0
Nicholas-Furness
Hmm. Looks like you're doing the right thing. Can you share the service with us? And which version of the Runtime are you using? Please DM me if you like.
It seems we have a bug where if there isn't a serviceURL (e.g. it's a Web Map) then we still return an empty URL, but we should be returning nil. This may be masking something else that's going on.
NickG
I used the code you provided on GitHub and it worked!  There was something clearly wrong with my code.  Sorry for sending you on a wild goose chase.  Your input was very helpful.  Thank you!
Nicholas-Furness
For reference, here's the code I provided:
import UIKit
import ArcGIS
class ViewController: UIViewController {
    @IBOutlet weak var mapView: AGSMapView!
    override func viewDidLoad() {
        super.viewDidLoad()
        let p = AGSPortal.arcGISOnline(withLoginRequired: false)
        let portalItem = AGSPortalItem(portal: p, itemID: "<feature service item id>")
                return
            if let url = portalItem.serviceURL {
                print("URL: \(url.absoluteString)")
            print("Type: \(portalItem.typeName)")
