Selecting an object in SceneView
900
6
03-27-2019 10:08 AM
AlexanderKulikov
New Contributor II
Hi! How to select an object from a ready-made scene loaded from the portal,  as in this exampleArcGIS Runtime SDK for Android 100.4.1
by Anonymous User
Not applicable
Hi Alexander,
Is there a particular way you're wanting to select an object that is different from how it's demonstrated in the sample? Is it by tapping on it or as a result of some other query?
https://github.com/Esri/arcgis-runtime-samples-android/tree/master/java/scene-layer-selection/
Cheers,
Trevor
AlexanderKulikov
New Contributor II
Clicking on it! I don't know how to work with: ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer(buildings); The example uses a single layer that is loaded by url. How to do the same but with loaded from the scene portal
by Anonymous User
Not applicable
Hi Alexander,
You should be able to access any scene layers in your scene with a call .getOperationalLayers() and then getting one or more layers from the LayerList. So something like:
for (Layer layer : scene.getOperationalLayers()) {
  if (layer instanceof ArcGISSceneLayer) {
    // follow the above sample for implementing identify and select on the scene layer
AlexanderKulikov
New Contributor II
I was able to choose only one layer, how to implement for multiple layers?
for (final Layer Layer: mSceneView.getScene().getOperationalLayers()) {
                            if (Layer instanceof ArcGISSceneLayer) {
                                sceneLayer = ((ArcGISSceneLayer) Layer);
mSceneView.setOnTouchListener(new DefaultSceneViewOnTouchListener(mSceneView) {
                    @Override
                    public boolean onSingleTapConfirmed(MotionEvent motionEvent) {
                        // clear any previous selection
                        sceneLayer.clearSelection();
                        android.graphics.Point screenPoint = new android.graphics.Point(Math.round(motionEvent.getX()),
                                Math.round(motionEvent.getY()));
                        // identify clicked feature
                        ListenableFuture<IdentifyLayerResult> identify = mSceneView
                                .identifyLayerAsync(sceneLayer, screenPoint, 10, false, 10);
                        identify.addDoneListener(() -> {
                            try {
                                // get the identified result and check that it is a feature
                                IdentifyLayerResult result = identify.get();
                                List<GeoElement> geoElements = result.getElements();
                                if (!geoElements.isEmpty()) {
                                    Log.d(TAG, "geoelement not empty");
                                    GeoElement geoElement = geoElements.get(0);
                                    if (geoElement instanceof Feature) {
                                        // select the feature
                                        sceneLayer.selectFeature((Feature) geoElement);
                            } catch (InterruptedException | ExecutionException e) {
                                String error = "Error while identifying layer result: " + e.getMessage();
                                Log.e(TAG, error);
                                Toast.makeText(MainActivity.this, error, Toast.LENGTH_LONG).show();
                        return true;
by Anonymous User
Not applicable
Hi!
We've got a very similar method for handling that! identifyLayersAsync(...).
There's a sample of it being implemented here (on a MapView, but the syntax is identical for a SceneView--both inherit a GeoView which implements identify). https://github.com/Esri/arcgis-runtime-samples-android/blob/65533272642bd366e31af709c250063ded30219a...
You'll want to call getElements() on the identify result to get the geoelements you want to select
Kind regards,
Trevor
AlexanderKulikov
New Contributor II
Hi!
It became even more unclear  How to call selectFeature?
