Hi Jason Knisley,Thank you for respond my question, I have called the featureLayer.getGraphicIDs(x, y, tolerance) method but I get this error on logcat 12-21 22:38:59.498: E/AndroidRuntime(3011): FATAL EXCEPTION: main
12-21 22:38:59.498: E/AndroidRuntime(3011): java.lang.IllegalStateException: Graphics layer is not bounded to a map!
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.GraphicsLayer.nativeGetGraphicsAt(Native Method)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.GraphicsLayer.getGraphicIDs(Unknown Source)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.arcgis.android.samples.attributeeditor.AttributeEditorActivity$2.onSingleTap(AttributeEditorActivity.java:148)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.MapOnTouchListener.onSingleTap(Unknown Source)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.esri.android.map.MapGestureDetector$a.onSingleTapConfirmed(Unknown Source)
12-21 22:38:59.498: E/AndroidRuntime(3011): at android.view.GestureDetector$GestureHandler.handleMessage(GestureDetector.java:281)
12-21 22:38:59.498: E/AndroidRuntime(3011): at android.os.Handler.dispatchMessage(Handler.java:99)
12-21 22:38:59.498: E/AndroidRuntime(3011): at android.os.Looper.loop(Looper.java:137)
12-21 22:38:59.498: E/AndroidRuntime(3011): at android.app.ActivityThread.main(ActivityThread.java:4514)
12-21 22:38:59.498: E/AndroidRuntime(3011): at java.lang.reflect.Method.invokeNative(Native Method)
12-21 22:38:59.498: E/AndroidRuntime(3011): at java.lang.reflect.Method.invoke(Method.java:511)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:790)
12-21 22:38:59.498: E/AndroidRuntime(3011): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
12-21 22:38:59.498: E/AndroidRuntime(3011): at dalvik.system.NativeStart.main(Native Method)
I'm not sure where to put the featureLayer.getGraphicIDs(x, y, tolerance) method, here my code at line 148 based error on logcat above public void onSingleTap(float x, float y) {
// convert event into screen click
pointClicked = mapView.toMapPoint(x, y);
// build a query to select the clicked feature
Query query = new Query();
query.setOutFields(new String[] { "*" });
query.setSpatialRelationship(SpatialRelationship.INTERSECTS);
query.setGeometry(pointClicked);
query.setInSpatialReference(mapView.getSpatialReference());
// call the select features method and implement the callbacklistener
featureLayer.getGraphicIDs(x, y, 15);
featureLayer.selectFeatures(query, ArcGISFeatureLayer.SELECTION_METHOD.NEW, new CallbackListener<FeatureSet>() {
// handle any errors
public void onError(Throwable e) {
Log.d(TAG, "Select Features Error" + e.getLocalizedMessage());
public void onCallback(FeatureSet queryResults) {
if (queryResults.getGraphics().length > 0) {
Log.d(TAG, "Feature found id=" + queryResults.getGraphics()[0].getAttributeValue(featureLayer.getObjectIdField()));
// set new data and notify adapter that data has changed
listAdapter.setFeatureSet(queryResults);
listAdapter.notifyDataSetChanged();
// This callback is not run in the main UI thread. All GUI
// related events must run in the UI thread,
// therefore use the Activity.runOnUiThread() method. See
// http://developer.android.com/reference/android/app/Activity.html#runOnUiThread(java.lang.Runnable)
// for more information.
AttributeEditorActivity.this.runOnUiThread(new Runnable() {
public void run() {
// show the editor dialog.
showDialog(ATTRIBUTE_EDITOR_DIALOG_ID);
am I wrong?
