I am attempting to come up the ArcGIS Android learning curve by developing a few simple applications which do only one particular task..In this case I am trying to have a map which will open at the users location. I looked at the Nearby sample, which works as is on my Nexus 7. I created another application using portions of the Nearby code but when the map opens, all I see is a grid. Here is the code I am using.
public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.main); // Retrieve the map and initial extent from XML layout mMapView = (MapView)findViewById(R.id.map); /* create a @ArcGISTiledMapServiceLayer */ tileLayer = new ArcGISTiledMapServiceLayer( "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); // Add tiled layer to MapView mMapView.addLayer(tileLayer); //now i will try to add code to zoom to current location mMapView.setOnStatusChangedListener(new OnStatusChangedListener(){ private static final long serialVersionUID = 1L; public void onStatusChanged(Object source, STATUS status){ if(source == mMapView && status==STATUS.INITIALIZED){ LocationService ls = mMapView.getLocationService(); ls.setAutoPan(false); ls.setLocationListener(new LocationListener(){ boolean locationChanged = false; public void onLocationChanged(Location loc){ if(!locationChanged){ locationChanged = true; double locx = loc.getLatitude(); double locy = loc.getLongitude(); Point wgspoint = new Point(locx, locy); Point mapPoint = (Point) GeometryEngine.project(wgspoint, SpatialReference.create(4326), mMapView.getSpatialReference()); Unit mapUnit = mMapView.getSpatialReference().getUnit(); double zoomWidth = Unit.convertUnits(SEARCH_RADIUS, Unit.create(LinearUnit.Code.MILE_US), mapUnit); Envelope zoomExtent = new Envelope(mapPoint, zoomWidth, zoomWidth); mMapView.setExtent(zoomExtent); } } public void onProviderDisabled(String arg0){ } public void onProviderEnabled(String arg0){ } public void onStatusChanged(String arg0, int arg1, Bundle arg2){ } }); ls.start(); } } }); } @Override protected void onPause() { super.onPause(); mMapView.pause(); }
