LicenseStatus of LicenseInfo readed fron JSON string is always expired
586
11-28-2017 11:56 PM
IvanBespalov
Hi all.
Each time application starts, we set license. Each time created from JSON string license is expired. It's offline application. We need to set license without internet connection, without asking each time from portal. How to?
private void setupEsriLicense() {
    try {
        appSettings = getSharedPreferences(Global.SETTINGS_FILE, MODE_PRIVATE);
        boolean getFromPortal = true;
        if (appSettings != null && appSettings.contains(Global.LICENSE_TAG)) {
            String licJson = appSettings.getString(Global.LICENSE_TAG, null);
            LicenseInfo licenseInfo = new LicenseInfo(licJson);
            LicenseResult licenseResult = ArcGISRuntimeEnvironment.setLicense(licenseInfo);
            LicenseStatus licenseStatus = licenseResult.getLicenseStatus();
            // licenseStatus is always EXPIRED
            if (licenseStatus == LicenseStatus.VALID) {
                getFromPortal = false;
        if (getFromPortal) {
            UserCredential credential = new UserCredential("username", "passwd");
            final Portal portal = new Portal("https://companyname.maps.arcgis.com");
            portal.setCredential(credential);
            portal.loadAsync();
            portal.addDoneLoadingListener(new Runnable() {
                @Override
                public void run() {
                    if (portal.getLoadStatus() == LoadStatus.LOADED) {
                        LicenseInfo licenseInfo = portal.getPortalInfo().getLicenseInfo();
                        if (licenseStatus == LicenseStatus.VALID) { // always VALID
                            SharedPreferences.Editor editor = appSettings.edit();
                            editor.putString(Global.LICENSE_TAG, licenseInfo.toJson());
                            editor.commit();
                        //TODO: remove from release
                         License runtimeLicense = ArcGISRuntimeEnvironment.getLicense();
                         Calendar cal = runtimeLicense.getExpiry(); // always +30 days
                         LicenseStatus ls = runtimeLicense.getLicenseStatus(); // always VALID
                         LicenseLevel ll = runtimeLicense.getLicenseLevel(); // always BASIC
                         LicenseType lt = runtimeLicense.getLicenseType(); // always NAMED_USER
    } catch (Exception ex) {
        Log.d(TAG, "setupEsriLicense", ex);
Thanks for your ansewers.
Ivan
Tags (3)
IvanBespalov
Solved.
//LicenseInfo licenseInfo = new LicenseInfo(licJson); // EXPIRED
LicenseInfo licenseInfo = LicenseInfo.fromJson(licJson); // VALID
Miracle!
