GeometryException when drawing a line on the map
987
01-19-2012 05:24 AM
_lkerArg_n
I tried to draw a line on a graphic layer added to map with the lines of code below. I get a geometry exception. What am I doing wrong?
                           Segment segment = new Line();    segment.setStart(startPoint);    segment.setEnd(endPoint);        Log.d("SEGMENT", "x: " + segment.getStartX() + "y: " + segment.getStartY());        Symbol lineSymbol = new SimpleLineSymbol(Color.BLUE, 4);    someGraphicsLayer.addGraphic(new Graphic(segment, lineSymbol));
SebastianGreifeneder1
New Contributor III
When you specify a Graphic you've to provide a "Geometry". IMO "Segment" itself isn't a Geometry, it's only part of it within polylines or polygons.
So, for graphics you should use Point, Polyline or Polygon.
_lkerArg_n
I did what I want to by using Polyline.
Polyline poly = new Polyline();
poly.startPath(startPoint);
poly.lineTo(endPoint);
allyGraphicsLayer.addGraphic(new Graphic(poly, new SimpleLineSymbol(Color.BLUE, 5)));
Still i wonder what did I do wrong in the code in the previous post.
BradFrecker
I have seen the exact same error, and would also like to know what is wrong with the above code.
IvanBespalov
Occasional Contributor III
mggl,
Unfortunately I can not compile your code now, but try to use Polyline when creating a Graphic.
try
    Polyline pLine = new Polyline();
    pLine.addSegment(segment, true);
    int addedGraphicId = someGraphicsLayer.addGraphic(new Graphic(pLine, lineSymbol));
    Log.d("Class/activity name for logging", "Graphic added id=" + addedGraphicId);
catch (Exception ex)
    // log exception ex.getMessage()
New Contributor III
IvanBespalov
Sebastian,
There are no any documentation from ESRI developers, where Segment is not a Geometry!
Also no any documentation about "witch Geometries types can be used with Graphic".
Finally:
you right, but I did not find any documentation about it.
