deleteFeature error
1637
6
10-05-2016 04:40 AM
IvanBespalov
Occasional Contributor III
We have a myGeodatabaseFeatureTable joined related with two another tables. I can add, I can edit, but I can't delete feature from this table.
myGeodatabaseFeatureTable.canDelete(featureId); // true
myGeodatabaseFeatureTable.deleteFeature(featureId); // AndroidRuntime: FATAL EXCEPTION
java.lang.RuntimeException: Abort due to constraint violation
at com.esri.core.geodatabase.GeodatabaseFeatureTable.nativeDeleteRows(Native Method)
at com.esri.core.geodatabase.GeodatabaseFeatureTable.deleteFeatures(SourceFile:212)
AlexanderNohe1
How did you perform the table join?
IvanBespalov
Alexander, sorry for my bad English. Not joined, but related. Related with two another tables.
AlexanderNohe1
Is this from a relationship class that you made in ArcMap?
IvanBespalov
No, database relationship class.
AlexanderNohe1
ibespalov‌ - To test whether this issue is with the relationship class itself or with the Android API, would you open the feature service in ArcMap or ArcGIS Online and try performing the delete there to see if it is successful?
IvanBespalov
We got solution for this problem. Database developer (not me) removed some relations, and now it works. But my question is still opened: why release SDK returns fatal RuntimeException, but not TableException. Why canDelete returns true? Thanks.
