I am a little confused about updating the bundle files. If I cache different extents under the same folder, will the tiles in bundle files updated and combine with the old bundle files? Does anyone has experience about it?
Not sure I fully understand what you are trying to do with respect to the Android SDK but in general when you update tiles in a compact cache, the entire bundle is not re-created. This post provides more detail.
Thanks for help. I understand that the bundle files are not re-created. But I did some demos that the results are not expected.
For example, I created an extent in vegas, cached it to level 5, stored the cache in a folder and use arcgislocaltilelayer to add layer. This is fine to show the cached map to level 5.
And then I created another extent in LA, one demo is caching it to level 8, stored into the same folder and after adding the layer, if the bundle files are not re-created but updated, the map should show vegas to level 5 and LA to level 8, right? But the map still shows only vegas to level 5, nothing shows in LA.
So I created another demo, which is only caching level 6,7,8 for LA, the folders are generated, but the map still shows only vegas, nothing is LA.
