Unable to set the service feature table url in android app
607
08-05-2021 10:14 PM
Latheesh
New Contributor II
Other Urls are working fine but when I enter the URL which created by me  It is not showing the actual map as mapviewer online
// here for the convenience of this tutorial.
ArcGISRuntimeEnvironment.setApiKey(Utils.arcGIS_api_key)
// create a map with the BasemapStyle topographic
val map = ArcGISMap(BasemapStyle.ARCGIS_TOPOGRAPHIC)
// create the service feature table
val serviceFeatureTable =
ServiceFeatureTable("https://services3.arcgis.com/df7XtT0Re4z8S561/arcgis/rest/services/redlist_species_data_7b024e64_0fd8_48a2_adf0_8e43737b5cb3/FeatureServer/0?token=hmhNtwfum0BzR5yrzisjJ8ksx2NDB5TGfEk12zN9vy-Jd3gNfiKqsxQDSc4ifrqiYsFvNR1yD-PAynWTqKYWaEA_PJOoFvO9FEQKwU6kO1ZS0ak6jsgyFsUrGIVSn-Qtf6bTyvWbj6__sWm6xucq4FfufOSnGhu82pKCYjfYiFiANZlEZzm2Y6OFYaKj-ONqYsteLoqXG-wx9nrw2eobHPrLm1WHEPyQ7kXpS5LjPmUrxjzC0w80OZKsNYGoB9Vp")
// val serviceFeatureTable =
// ServiceFeatureTable("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Hurricanes/MapServer/0")
// create the feature layer using the service feature table
val featureLayer = FeatureLayer(serviceFeatureTable)
map.operationalLayers.add(featureLayer)
mapView.map=map
// mapView.setViewpoint(Viewpoint(7.9465, 1.0232, 20000000.0))
Nicholas-Furness
I think you shouldn't include the query parameters in the URL. Try simply using this when creating the ServiceFeatureTable.
Note, you can call loadAsync on the ServiceFeatureTable and see if there's a loadError to help home in on the cause of issues like this. All Runtime classes that work with remote resources will implement the Loadable pattern. See this page for more details.
Hope that helps.
Nicholas-Furness
Hope that helps.
Latheesh
New Contributor II
Thank you for the response
