Offline Custom Marker Symbols
1561
04-29-2018 06:48 PM
JoelSmith-Lowe
Hi All,
Anyone ever had to use Custom Markers from an offline source before ?
Currently going through and trying to find some information but everything I have found uses online URL links instead of accessing image files from offline storage source (e.g Internal/External Storage)
Again, I have found something for offline but it is for 10.2 and not 100
*Rolls Eyes*
Display Device Location—ArcGIS Runtime SDK for Android | ArcGIS for Developers
ShellyGill1
HI Joel - you might find the info in the following topic useful - shows loading PictureMarkerSymbols from a file path to an image, and from an app resource (as well as the online URL!) - Symbols and renderers—ArcGIS Runtime SDK for Android | ArcGIS for Developers .  The code for using an app resource is taken from this SDK sample - arcgis-runtime-samples-android/MainActivity.java at 7438b7d0642390cf13144ea9d845d4b3713fdb31 · Esri/... .
Hope this helps,
Shelly
JoelSmith-Lowe
Hi Shelly,
Thank you, I have been able to get it working using drawables that you can insert directly into your app through Android Studio.
After having a more careful look using the link below I was able to identify two offline methods. (Drawables, External File Storage)
Link: Picture Marker Symbols—ArcGIS Runtime SDK for Android | ArcGIS for Developers
After inserting the symbol in Android Studio and adding the below code to a button under the mapview I have been able to get it working to a predefined location...
public void symbol3(View v) {
    mGraphicsOverlay =
new GraphicsOverlay();
mMapView.getGraphicsOverlays().add(mGraphicsOverlay);
//[DocRef: Name=Picture Marker Symbol Drawable-android, Category=Fundamentals, Topic=Symbols and Renderers]
    //Create a picture marker symbol from an app resource
BitmapDrawable pinStarBlueDrawable = (BitmapDrawable) ContextCompat.getDrawable(this, R.drawable.pin_star_blue);
    final
PictureMarkerSymbol pinStarBlueSymbol = new PictureMarkerSymbol(pinStarBlueDrawable);
//Optionally set the size, if not set the image will be auto sized based on its size in pixels,
    //its appearance would then differ across devices with different resolutions.
pinStarBlueSymbol.setHeight(40);
pinStarBlueSymbol.setWidth(40);
//Optionally set the offset, to align the base of the symbol aligns with the point geometry
pinStarBlueSymbol.setOffsetY(
11); //The image used for the symbol has a transparent buffer around it, so the offset is not simply height/2
pinStarBlueSymbol.loadAsync();
//[DocRef: END]
Point pinStarBluePoint = new Point(000.000000, -00.000000, SpatialReferences.getWgs84());
Graphic pinStarBlueGraphic = new Graphic(pinStarBluePoint, pinStarBlueSymbol);
mGraphicsOverlay.getGraphics().add(pinStarBlueGraphic);
I am now currently working on using this code but adding the ability to do onclick like below....
public void symbol1(View v) {
// Symbol 1 -
Point initialPoint = new Point(0,0, SpatialReferences.getWgs84());
coordinateLocation = new Graphic(initialPoint,
                new
SimpleMarkerSymbol(SimpleMarkerSymbol.Style.TRIANGLE, Color.YELLOW, 20f));
mMapView.getGraphicsOverlays().add(new GraphicsOverlay());
mMapView.getGraphicsOverlays().get(0).getGraphics().add(coordinateLocation);
toCoordinateNotationFromPoint(initialPoint);
mMapView.setOnTouchListener(new Symbol1MapTouchListener(this, mMapView));
Toast.makeText(MapsActivity.this,
"You Just Pressed Symbol 1!", Toast.LENGTH_LONG).show();
If you have any suggestions on how to achieve this it would be most appreciated. My latest attempt is below.
    final PictureMarkerSymbol pinStarBlueSymbol = new PictureMarkerSymbol(pinStarBlueDrawable);
    coordinateLocation = new Graphic(initialPoint, new Graphic(pinStarBluePoint, pinStarBlueSymbol));
    mGraphicsOverlay = new GraphicsOverlay();
    //mMapView.getGraphicsOverlays().add(mGraphicsOverlay);
    mMapView.setOnTouchListener(new ShowCoordinatesMapTouchListener(this, mMapView));
            "You Just Pressed Symbol 3!", Toast.LENGTH_LONG).show();
    //[DocRef: END]
    //Point pinStarBluePoint = new Point(000.000000, -00.000000, SpatialReferences.getWgs84());
   // Graphic pinStarBlueGraphic = new Graphic(pinStarBluePoint, pinStarBlueSymbol);
    //mGraphicsOverlay.getGraphics().add(pinStarBlueGraphic);
JoelSmith-Lowe
Resolved it with the below code.
    coordinateLocation = new Graphic(initialPoint, pinStarBlueSymbol);
    pinStarBlueSymbol.setOffsetY(11); //The image used for the symbol has a transparent buffer around it, so the offset is not simply height/2
    //[DocRef: END]
    //Point pinStarBluePoint = new Point(153.057137, -26.785357, SpatialReferences.getWgs84());
ShellyGill1
Good to hear you have solved things Joel. I presume you're doing something in your ShowCoordinatesMapTouchListener like converting the touch location received in `onSingleTapConfirmed` from screen coordinates to map coordinates using `MapView.screenToLocation` method, which is correct.
