Map Surface not showing
985
9
09-28-2021 09:46 AM
HamdiJOUINI
mapstatus is loaded but the surface is not showing with a low of network connection
HamdiJOUINI
Any Solution please about this subject
HamdiJOUINI
the map need a lot of time and a good network connection to be loaded whith surface . I ask if there is a solution to load partially the map (tiles) even with a low internet connection
ChanganShi1
You may consider using offline map to load the base layers.
HamdiJOUINI
at first launch the map show properly but after invoke the map more time the font map will not show
Tags (3)
ChanganShi1
The Font of the map is not shown, do you mean the labeling?  It may be scale-dependent. If you could provide some screenshots, it would be very helpful.
HamdiJOUINI
i mean the scale is not showing on the map
HamdiJOUINI
HamdiJOUINI
any reply please !
ChanganShi1
Do you mean the scale toolbar or label is not showing? It is still not very clear what is your problem.
