Using ArcGIS Pro 3.0.0 with Roads and Highways
1333
06-23-2022 04:44 PM
GraemeBrowning
When I started ArcGIS Pro 2.9.3 this morning I was offered an upgrade to ArcGIS Pro 3.0.0.
I have not performed that upgrade but, if I had, would all parts of ArcGIS Roads and Highways (including Location Refencing) be certified to work with it?
- Graeme
NathanEasley
Hi Graeme,
Yes, Roads and Highways has been certified in ArcGIS Pro 3.0 and has many new features including event editing in Pro.  However, Roads and Highways is a service based extension which means you'd want to upgrade your Enterprise environment to stay in alignment with Pro.  Pro 3.0's release companion is Enterprise 11.0, which should release sometime in the middle of next month.  I'd recommend holding off on any Roads and Highways Pro upgrade to 3.0 until you're able to upgrade Enterprise to 11.0 to keep the functionality in alignment.
Nathan
ArcGIS Roads and Highways team
DanPatterson
MVP Esteemed Contributor
The 3.0 help rolled out today.  Is something missing from it?
What is ArcGIS Roads and Highways?—ArcGIS Pro | Documentation
And in the What's new in ArcGIS Pro 3.0—ArcGIS Pro | Documentation
about an 8/10ths scroll down the page is a section on....
Roads and Highways
At ArcGIS Pro 3.0, Roads and Highways introduces linear referenced event data editing capabilities. Event features can be created using standard A .......
... sort of retired...
GraemeBrowning
What's new in ArcGIS Pro 3.0—ArcGIS Pro | Documentation describes some nice new features under the heading of Roads and Highways but makes no mention of whether upgrading ArcGIS Pro from 2.9.3 to 3.0.0 is expected to introduce any higher System Requirements on other components of that Production extension.
I need to be mindful of my ArcGIS Pro and ArcPy work staying in sync with an SQL Server Enterprise Geodatabase and Portal for ArcGIS maps and applications.
I'm hoping the Roads and Highways Team can provide assurances or warn of anything I need to be wary of before upgrading ArcGIS Pro to 3.0.0.
NathanEasley
Hi Graeme,
Nathan
