Hi Nathan
I just tested again and the error I get when I choose the Derived Line Network and try to remove it is:
ERROR 130185: You have chosen to remove LRS networks which have related centerline sequence records. Use the Delete Routes tool to clean your network data from the LRS, and then proceed.
Failed to execute (RemoveLRSEntity).
The procedure I used for my test was:
- Copy/paste the LRS Dataset (which has a Line Network and a Derived Line Network based on it) from an ArcGIS Enterprise 11.0 geodatabase into a new file geodatabase using ArcGIS Pro 3.1.3. I'm mindful that this may be introducing a version incompatibility but that's something that we'll only be able to reconcile soon.
- Open Remove LRS Entity tool in the Geoprocessing pane
- Set the LRS Workspace, LRS Entity Type and choose the Derived Line Network from the LRS Entity Name pick list.
I'm hoping to test this in an Enterprise Geodatabase, and in an ArcGIS Enterprise 11.2 / ArcGIS Pro 3.2 configuration soon.
Re-reading the error message above I wondered whether I might need to try and use Delete Routes on the Derived Line Network before using Remove LRS Entity but I was blocked when I tried to do that too:
