Uploading large files using addItem and addPart
1456
02-03-2019 03:00 PM
ChrisColla
I am using the addItem and addPart APIs from the ArcGIS REST API to upload large files (eg >1GB) to an ArcGIS Portal.
During my testing I have found the disk on the server keeps filling up. Even thought this is only a test server, and the disk is only 100GB, I don't think this should be happening. Even though my test uploads are up to 30GB in size, I have always deleted the content from portal before my next test.
My theory is that any time an upload fails because a user aborts the operation, or there is a network failure, that there are "parts" that have been uploaded to the server that no-one has called the commit API to finalize the upload. Since no-one is keeping track of failed uploads, there are a whole bunch of zombie parts filling up the hard disk.
Does anyone know how long a non-committed part will remain on the disk? Anyone got any hints on how to manage these non-committed parts?
RobertBorchert
Honored Contributor
Why not simply use ArcCatalog?
We just finished setting up Portal and completely loaded it from ArcCatalog
JoshuaBixby
MVP Esteemed Contributor
In all fairness to the OP, the ArcGIS API for Python | ArcGIS for Developers "provides simple and efficient tools for sophisticated vector and raster analysis, geocoding, map making, routing and directions, as well as for organizing and managing a GIS with users, groups and information items."  As much as ArcCatalog may work for people, falling back to ArcCatalog because ArcGIS API for Python doesn't work isn't a great solution and let's Esri off the hook.
EarlMedina
I think this would be determined by your current cleanup schedule settings: About server directories—ArcGIS Server Administration (Linux) | ArcGIS Enterprise
If I understand your problem correctly, you may want to take a look at your uploads folder to see what's in there after running your tests. I've had similar issues when testing upload of large raster datasets to an Image Service.
