Unable to view services
1159
05-10-2010 06:50 AM
JoshObrecht
I am unable to view the maps that are contained within my services through both Flex and through the Javascript link within the service in AGS Services Directory.  I have tried running Post-Intall for AGS and this did not cure this issue.  Can anyone help?
AravindhBaskaran
I am running into the same issue. I'd appreciate any help. Thanks.
nicogis
Have you seen in C:\inetpub\wwwroot\arcgis\rest\restlog.txt  if there is something useful ?
Have you seen call with fiddler?
MattCharton
Have you seen this post: http://forums.arcgis.com/threads/5887-Can-see-service-in-REST-but-not-in-ArcMap
The error mentioned in the title is not exactly what you're mentioning, but I was having the exact problem you guys are having, and it the last suggestion in the post completely solved my issue: Changing the SoapURL in the rest.config.
