Trying to filter createReplica by date with an ArcREST Script
850
03-28-2017 11:31 AM
DerekWaggenspack
Ok, so I am trying to use the ArcRest API to try and export a feature class with attachments to a File Geodatabase.  I believe because my file is too large, it is failing out.  I have copied the feature service and tried the export script and it works on the copied one [with far fewer data points].  I wondered if there was a way I could filter the data by last edited date.  I use editor tracking on an ArcGIS Online Hosted Layer.  In the request, how would I set the filter to only get stuff newer than yesterday?   Thanks in advance!
RandyBurton
See the script in this thread for an idea: query-minimum-date-using-rest-service. Note the comment on line 35. You would use the EditDate field.
Have you checked this page: Sync workflow examples?  The topic Workflow Example 4: Setting up sync using LayerQueries contains this:
    "layerQueries": {
        "1": {
            "queryOption": "useFilter",
            "useGeometry": false,
            "where": "region = 'Southwest'"
The "where" would be edited to something like:
"where" : "EditDate >= DATE '2016-05-29 18:30:00'"
