Too big expires response
1609
03-06-2014 06:05 AM
EkaitzHernandez
Hi All!
I have problem when I generate a token with this endpoint 'https://www.arcgis.com/sharing/rest/generateToken'
It doesn't matter what I pass to 'expiration' parameter than I receive very big values for 'expires'
  "token": "<token generated>",
  "expires": <date shown in UNIX time>
  "ssl": false | true
I receive this timestamp in "expires" property-> 13941214241 translates to Wednesday, October 12th 2411, 15:30:41 (GMT) when the maximun should be 15 days.
More information here http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#//02r3000000m5000000
Thanks!!
Ekiatz
RichardWatson
The ESRI link says that it is returning milliseconds.  It looks like the date you posted is correct if they returned seconds.
I am wondering if you left off a digit in the number you posted?
Here is the code to perform the conversion:
        static void Main(string[] args)
            const long millisecondsSinceEpoch = 13941214241;
            var time = new DateTime(1970, 1, 1, 0, 0, 0, DateTimeKind.Utc);
            var expires = time.AddMilliseconds(millisecondsSinceEpoch);
            Console.WriteLine(expires);
EkaitzHernandez
Ok sorry I didn't see that, but if is miliseconds 13941214241  is 161 days when the maximun should be 15 days.
RichardWatson
Please post the complete JSON response which contains the token which was issued.
