Retrieve ArcGIS Pro license activity through REST API for python
1234
01-25-2024 06:56 AM
Jelle_Stu_PR
In Portal you can see the ArcGIS Pro license activity through this button:
My simple question is, can you obtain this ArcGIS Pro activity through the REST API for python?
With the following code you can get what licenses are assigned to what user and when they had their last login:
gis.admin.license.get('ArcGIS Pro')
print(agpro.all())
returns
[{'username': 'name 1', 'lastLogin': 1706174509800, 'disconnected': False, 'entitlements': ['arcgispro-extension1', 'arcgispro-extension2', 'arcgispro-extension3']},{other users with arcgis pro extension licenses},{'username': 'username1', 'lastLogin': 1706098700941, 'disconnected': False, 'entitlements': ['desktopAdvN']}]
What does the last login mean in this case? Last time they logged into Portal or the last time they used ArcGIS Pro?
Furthermore, the issue with this is that it only returns the users that have additional ArcGIS Pro extension licenses or the single user that has an ArcGIS Pro Advanced license through Portal. All the named used licenses that are given through the user types "GIS Professional Basic/Standard/Advanced' are not returned.
Does anybody know a way how to natively retrieve the ArcGIS Pro license activity of all named users using the REST API for Python?
best,
Jelle Stuurman
JoshuaClanton
I'm also looking for a very similar script. Sadly, Esri does not provide any documentation on it currently..
Katie_Clark
I'm also looking to do something similar to help with our license management. Did you ever find a solution?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
