Requesting a few particular records causes an "Unable to perform query" error.
1968
03-07-2011 05:05 AM
IDVSolutions
Using Arc GIS 9.3.1, I recently published a feature class map to the REST API.  For the most part, it works well; returning the results I ask for.  However, I have noticed that when certain records should be included in the result, I receive a generic "Unable to perform query. Please check your parameters." error.
The type of query does not seem to matter, for example, when I query with envelope geometry, if any of these records should be returned, I get the error.  If I move the geometry so that the offending record should not be included, I will get the intended results.  A further example, when I query using the Text= argument, I get the same error (in this case I only expect one record to be returned).
I am using Internet Explorer to demonstrate the problem.  (I have removed my program from the equation)
I view the record in Arc Map and the shape renders correctly.  The data record is viewable.  This appears to be a problem in the REST API.
I have vewied, at Verbose level, the logs in ArcGIS Server Manger, but there is not a clear indication that anything is wrong.  There are certainly no errors.
I have viewed the Windows Application log.  There are no errors at the time I make the REST call.
I have asked my client to review the records that I have identified.  To me, they look like any other records, and nothing is obviously wrong.
Thanks for your help!
PeterSiebert
I have run into this when the field assigned to be the Display field for the layer in the MXD contains characters that need to be escaped in SQL WHERE clauses, for example apostrophes such as might be found in an Irish name like O'Hara. Any query that would include the offending record fails with this error (even strictly spatial queries). Try assigning something like the FID to be the Display field for the layer instead.
Peter Siebert
GIS Developer
Harvard Planning & Project Mgmt
Harvard University
