Query ArcGIS REST Service to retrieve data with an intersect filter by POST
506
09-27-2024 08:25 AM
FranAcuñaParra
Hello team,
I'm trying to query a layer from an ArcGIS REST service (FeatureServer) based on an intersect filter by polygon. It works generally fine, but there is one scenario where I can't make it work. This scenario is when the value of the geometry parameter for the query is too big. This is because in the app that I'm working on, the user can filter through the area of a Spanish state so it contains a lot of coordinates and the URL is too long. To solve this, I've tried to send the request to the API REST Service with POST method, but the result is the same. I've also tried to send a JSON body or form-data with the POST method but with no result. Am I doing something wrong?
Any help would be appreciated.
This is an example of the query (you won't be able to access the service because VPN is needed).
https://devgeo.dfa.es/geoaraba/rest/services/OGC_ARABA/WMS_Geoteka/FeatureServer/0/query?&spatialRel=esriSpatialRelIntersects&returnGeometry=true&outFields=*&f=geojson&inSR=25830&outSR=25830&geometryType=esriGeometryPolygon&geometry=%7B%22rings%22%3A%5B%5B%5B528751.4584211947%2C4707330.5969750015%5D%2C%5B528827.73267354%2C4707162.220634268%5D%2C%5B529035.7986096442%2C4706716.558814984%5D%2C%5B528898.0432736593%2C4706576.971028482%5D%2C%5B528646.7922382362%2C4706320.499283909%5D%2C%5B528577.7799341662%2C4706030.806476952%5D%2C%5B528521.0103035776%2C4705761.831696731%5D%2C%5B528601.1002071892%2C4705491.936712808%5D%2C%5B528394.1496918541%2C4705057.01262615%5D%2C%5B528414.2516546038%2C4704962.381254426%5D%2C%5B528415.0418287613%2C4704958.677701802%5D%2C%5B528423.0478360777%2C4704926.857014762%5D%2C%5B528428.4786817916%2C4704914.699695232%5D%2C%5B528440.3166943773%2C4704888.116360207%5D%2C%5B528446.8204903458%2C4704873.528926438%5D%2C%5B528454.9729066797%2C4704860.147034174%5D%2C%5B528467.9930841188%2C4704838.768237021%5D%2C%5B528485.16765955%2C4704810.566351544%5D%2C%5B528540.5299215162%2C4704720.768663631%5D%2C%5B528551.8775091385%2C4704702.36151191%5D%2C%5B528559.6581603334%2C4704689.728097381%5D%2C%5B528572.7670740101%2C4704668.467012632%5D%2C%5B528580.6702761798%2C4704656.569565185%5D%2C%5B528585.3869853496%2C4704649.461878935%5D%2C%5B528600.8221745149%2C4704626.209687031%5D%2C%5B528623.277020876%2C4704592.358164144%5D%2C%5B528634.1430833765%2C4704572.669035898%5D%2C%5B528634.8495957679%2C4704571.399502502%5D%2C%5B528641.1531525679%2C4704559.002590734%5D%2C%5B528645.6481909401%2C4704550.180185615%5D%2C%5B528652.9463490552%2C4704534.683457265%5D%2C%5B528654.9990434014%2C4704529.182878624%5D%2C%5B528659.3733390517%2C4704517.417877247%5D%2C%5B528663.0098668898%2C4704501.957518013%5D%2C%5B528664.3385954493%2C4704496.586332785%5D%2C%5B528668.8496740748%2C4704478.4963589655%5D%2C%5B528675.6314672845%2C4704443.197048282%5D%2C%5B528678.2116396191%2C4704429.71811021%5D%2C%5B528679.946750322%2C4704417.088882961%5D%2C%5B528682.2071534236%2C4704400.592907496%5D%2C%5B528687.3902479799%2C4704362.741689115%5D%2C%5B528693.0783043584%2C4704320.596804815%5D%2C%5B528693.6187003853%2C4704316.649186368%5D%2C%5B528695.7732412526%2C4704300.777752272%5D%2C%5B528696.1236036367%2C4704298.160669624%5D%2C%5B528696.8091104754%2C4704293.036770006%5D%2C%5B528697.6234777312%2C4704287.096945611%5D%2C%5B528698.5985061938%2C4704279.789668263%5D%2C%5B528699.0703784458%2C4704276.349269894%5D%2C%5B528700.8292842595%2C4704263.337385852%5D%2C%5B528701.9789270988%2C4704254.861286014%5D%2C%5B528703.8934628628%2C4704238.12078047%5D%2C%5B528705.5173324451%2C4704223.843126906%5D%2C%5B528706.8496237571%2C4704212.2490014015%5D%2C%5B528709.0016075941%2C4704193.42776179%5D%2C%5B528714.9825555641%2C4704141.176531492%5D%2C%5B528715.1432519531%2C4704139.801701093%5D%2C%5B528721.7584465945%2C4704084.147031699%5D%2C%5B528727.3330430539%2C4704037.388019016%5D%2C%5B528727.8992639779%2C4704032.557667491%5D%2C%5B528731.299971923%2C4704006.341252556%5D%2C%5B528737.3414846298%2C4703977.082992863%5D%2C%5B528741.8435449909%2C4703955.93168525%5D%2C%5B528743.4996523317%2C4703948.192885629%5D%2C%5B528750.3225424248%2C4703922.828835893%5D%2C%5B528758.8601342222%2C4703889.85848655%5D%2C%5B528766.2777503828%2C4703861.738244173%5D%2C%5B528769.6903341564%2C4703848.79863283%5D%2C%5B528782.1024896518%2C4703810.856639956%5D%2C%5B528792.1097243427%2C4703783.210222681%5D%2C%5B528794.2680785686%2C4703777.231391343%5D%2C%5B528805.4783802802%2C4703751.480316325%5D%2C%5B528806.1492163524%2C4703749.93833151%5D%2C%5B528817.7678563709%2C4703721.8717182055%5D%2C%5B528822.9274818634%2C4703709.630561095%5D%2C%5B528830.7565369491%2C4703691.030091226%5D%2C%5B528847.2730860998%2C4703660.5119027505%5D%2C%5B528866.5197435998%2C4703623.288789466%5D%2C%5B528880.3218782113%2C4703601.137792774%5D%2C%5B528887.8509706064%2C4703589.068121326%5D%2C%5B528895.1514651692%2C4703578.718832328%5D%2C%5B528910.30954%2C4703557.228072371%5D%2C%5B528913.2479817013%2C4703553.679861474%5D%2C%5B528931.7099306446%2C4703531.349450618%5D%2C%5B528940.5219041843%2C4703523.308892833%5D%2C%5B528946.1395799055%2C4703518.19756684%5D%2C%5B528956.6875866594%2C4703509.928821851%5D%2C%5B528961.8503643697%2C4703505.911689428%5D%2C%5B528966.7432313312%2C4703502.886530288%5D%2C%5B528981.4882138964%2C4703493.833409999%5D%2C%5B529001.1387653411%2C4703484.043015992%5D%2C%5B529011.7183390047%2C4703480.636939446%5D%2C%5B529021.8469104941%2C4703477.3834816385%5D%2C%5B529032.9217562547%2C4703475.612588486%5D%2C%5B529041.9722867785%2C4703474.156956482%5D%2C%5B529046.1823768585%2C4703473.762542376%5D%2C%5B529055.511018684%2C4703472.896588333%5D%2C%5B529061.343678464%2C4703472.9208966335%5D%2C%5B529078.1770855627%2C4703473.013148047%5D%2C%5B529098.8793055322%2C4703473.106872655%5D%2C%5B529107.0227877648%2C4703473.16293242%5D%2C%5B529108.0699307906%2C4703473.4689112995%5D%2C%5B529121.8001127919%2C4703477.638403072%5D%2C%5B529131.7770115405%2C4703480.659371206%5D%2C%5B529141.2598180397%2C4703483.538518257%5D%2C%5B529153.1023175474%2C4703487.119032005%5D%2C%5B529193.5906285581%2C4703503.303010196%5D%2C%5B529197.2098383019%2C4703504.723208171%5D%2C%5B529212.8733651855%2C4703510.879787483%5D%2C%5B529242.5196520778%2C4703522.553351477%5D%2C%5B529262.3477649109%2C4703530.338507805%5D%2C%5B529274.8189512567%2C4703535.378375745%5D%2C%5B529311.6502568667%2C4703550.230822094%5D%2C%5B529341.8035686488%2C4703562.399743478%5D%2C%5B529372.8272583236%2C4703574.741634349%5D%2C%5B529406.423253872%2C4703588.102286033%5D%2C%5B529427.6380150311%2C4703594.378325319%5D%2C%5B529439.6721718016%2C4703597.95272655%5D%2C%5B529467.5668511778%2C4703604.639607884%5D%2C%5B529470.6867408366%2C4703605.388409255%5D%2C%5B529474.4704134272%2C4703606.301853213%5D%2C%5B529521.0617238763%2C4703614.097865312%5D%2C%5B529539.4015984015%2C4703617.522584826%5D%2C%5B529572.2894505664%2C4703623.6498916615%5D%2C%5B529573.4475451182%2C4703623.897556036%5D%2C%5B529593.2381268293%2C4703628.196589231%5D%2C%5B529594.5429110018%2C4703628.672919399%5D%2C%5B529603.8016867533%2C4703632.059261384%5D%2C%5B529620.7435274862%2C4703641.296936404%5D%2C%5B529628.5072637649%2C4703645.53761837%5D%2C%5B529650.0573609071%2C4703657.943340986%5D%2C%5B529651.4487598452%2C4703658.88348205%5D%2C%5B529655.8804804169%2C4703661.910972057%5D%2C%5B529669.0799230577%2C4703670.926839412%5D%2C%5B529684.4297111635%2C4703682.960507793%5D%2C%5B529717.7599899146%2C4703723.759362997%5D%2C%5B529732.9385077853%2C4703739.551241586%5D%2C%5B529736.5402213725%2C4703743.288742038%5D%2C%5B529754.2031833257%2C4703761.636392849%5D%2C%5B529774.3430581621%2C4703782.569207297%5D%2C%5B529780.2673500923%2C4703788.736737938%5D%2C%5B529782.428901277%2C4703790.84977502%5D%2C%5B529784.3478564905%2C4703792.719029284%5D%2C%5B529792.8472053774%2C4703800.979296193%5D%2C%5B529804.0164067174%2C4703813.333520624%5D%2C%5B529815.5114357452%2C4703821.996462752%5D%2C%5B529829.2206647075%2C4703834.258572214%5D%2C%5B529837.0193531823%2C4703840.603312903%5D%2C%5B529839.7563459408%2C4703842.807086218%5D%2C%5B529846.4367783278%2C4703848.2275567725%5D%2C%5B529854.4718714078%2C4703854.529181542%5D%2C%5B529865.4207965954%2C4703863.108903675%5D%2C%5B529883.6481322153%2C4703877.096968486%5D%2C%5B529929.6503968135%2C4703909.799810324%5D%2C%5B529934.2432453878%2C4703913.063451227%5D%2C%5B529957.170415969%2C4703929.403587388%5D%2C%5B529999.7086910813%2C4703960.576482205%5D%2C%5B530001.9533888538%2C4703962.211769471%5D%2C%5B530007.4803713126%2C4703966.266523359%5D%2C%5B530010.4020476126%2C4703968.419630195%5D%2C%5B530017.1207241111%2C4703973.47254709%5D%2C%5B530035.871029075%2C4703987.602809322%5D%2C%5B530042.390973348%2C4703992.507766083%5D%2C%5B530045.2230543838%2C4703994.888521769%5D%2C%5B530077.4424463996%2C4704021.971501976%5D%2C%5B530084.180313679%2C4704027.686543221%5D%2C%5B530102.2605750393%2C4704043.0497442605%5D%2C%5B530106.5121669252%2C4704046.657683006%5D%2C%5B530142.5522659273%2C4704081.267401928%5D%2C%5B530154.5434796208%2C4704092.786720505%5D%2C%5B530166.7471850882%2C4704104.667386886%5D%2C%5B530175.8263990466%2C4704113.511368825%5D%2C%5B530192.867408346%2C4704130.091155042%5D%2C%5B530202.4097360907%2C4704139.378482163%5D%2C%5B530204.6886913733%2C4704141.602390492%5D%2C%5B530210.4435864436%2C4704147.519156829%5D%2C%5B530214.3168346878%2C4704151.522671196%5D%2C%5B530249.2573618826%2C4704187.488450233%5D%2C%5B530250.9404538724%2C4704189.216951727%5D%2C%5B530272.8012093095%2C4704212.746581079%5D%2C%5B530305.7590442789%2C4704254.6322450265%5D%2C%5B530306.2216343924%2C4704255.207983386%5D%2C%5B530324.0192211004%2C4704279.300974225%5D%2C%5B530326.3495019547%2C4704283.283054625%5D%2C%5B530327.0236460043%2C4704284.440792725%5D%2C%5B530329.5004164294%2C4704288.688304553%5D%2C%5B530338.7332958532%2C4704304.52795471%5D%2C%5B530338.7625687085%2C4704304.586925519%5D%2C%5B530352.261545609%2C4704329.102438348%5D%2C%5B530358.9163626757%2C4704345.291213941%5D%2C%5B530363.117354949%2C4704358.74778383%5D%2C%5B530363.6794593551%2C4704366.980885378%5D%2C%5B530363.7215416579%2C4704367.488588536%5D%2C%5B530361.6203761229%2C4704378.711061458%5D%2C%5B530358.7572540523%2C4704390.297965144%5D%2C%5B530356.9685580953%2C4704397.579308946%5D%2C%5B530349.470230738%2C4704427.622529037%5D%2C%5B530346.4274801809%2C4704439.782286566%5D%2C%5B530344.8120875831%2C4704446.262611186%5D%2C%5B530336.3091486427%2C4704483.25932093%5D%2C%5B530333.9689024048%2C4704493.458198994%5D%2C%5B530331.9465967366%2C4704513.720375746%5D%2C%5B530331.800065047%2C4704515.161358345%5D%2C%5B530332.0209143946%2C4704539.051983487%5D%2C%5B530332.2815755365%2C4704558.882654113%5D%2C%5B530332.3434125622%2C4704563.332792919%5D%2C%5B530333.5930322052%2C4704578.129430695%5D%2C%5B530334.898031436%2C4704583.592621017%5D%2C%5B530337.1314300703%2C4704592.847737746%5D%2C%5B530339.2402632273%2C4704605.279709255%5D%2C%5B530339.9818397511%2C4704609.593030635%5D%2C%5B530343.1573213972%2C4704619.492109516%5D%2C%5B530345.2624492209%2C4704625.988465681%5D%2C%5B530352.1495765565%2C4704644.707709818%5D%2C%5B530361.7906897444%2C4704664.998178067%5D%2C%5B530362.1491647878%2C4704665.742599481%5D%2C%5B530373.6287329341%2C4704689.328729139%5D%2C%5B530384.6292318021%2C4704711.02983121%5D%2C%5B530397.5101607874%2C4704734.857318842%5D%2C%5B530403.7492937744%2C4704746.380350393%5D%2C%5B530417.8984646134%2C4704775.582393428%5D%2C%5B530423.5172690772%2C4704787.14679901%5D%2C%5B530434.9521363989%2C4704810.732432402%5D%2C%5B530436.5909597395%2C4704814.100776072%5D%2C%5B530440.729914771%2C4704821.378128351%5D%2C%5B530453.3006822615%2C4704843.453538358%5D%2C%5B530458.1794287924%2C4704852.04326774%5D%2C%5B530468.1888529619%2C4704865.619936638%5D%2C%5B530473.8370714948%2C4704872.109532426%5D%2C%5B530476.1434569249%2C4704874.737937592%5D%2C%5B530483.7309704727%2C4704881.706722448%5D%2C%5B530484.9463335118%2C4704882.307779157%5D%2C%5B530492.5184620919%2C4704886.040379602%5D%2C%5B530495.3518474994%2C4704886.31755039%5D%2C%5B530503.1435275057%2C4704887.10919466%5D%2C%5B530518.8002155846%2C4704888.803152482%5D%2C%5B530537.5094390325%2C4704891.297484923%5D%2C%5B530552.0532268255%2C4704892.589480501%5D%2C%5B530571.3932216143%2C4704894.321767756%5D%2C%5B530592.5372591631%2C4704895.392739494%5D%2C%5B530602.6406239171%2C4704895.907804464%5D%2C%5B530619.4809635788%2C4704895.327193589%5D%2C%5B530623.0766183408%2C4704895.159121659%5D%2C%5B530633.280242108%2C4704894.696481759%5D%2C%5B530643.422509854%2C4704893.0788813615%5D%2C%5B530649.5463348745%2C4704892.090845601%5D%2C%5B530663.5090504572%2C4704889.548659704%5D%2C%5B530666.5675662499%2C4704888.988441396%5D%2C%5B530686.6772815394%2C4704883.553486939%5D%2C%5B530704.9795975655%2C4704877.867913336%5D%2C%5B530707.4263536021%2C4704877.099081428%5D%2C%5B530726.2126173986%2C4704872.158528727%5D%2C%5B530742.4492556733%2C4704867.883421175%5D%2C%5B530743.3065322824%2C4704867.659202659%5D%2C%5B530759.0799464969%2C4704864.647120889%5D%2C%5B530774.6981975998%2C4704861.67116242%5D%2C%5B530791.8590279307%2C4704857.076630291%5D%2C%5B530801.2818872945%2C4704854.573488562%5D%2C%5B530809.8012645218%2C4704852.728301747%5D%2C%5B530829.8989380366%2C4704848.3969057%5D%2C%5B530830.9995221402%2C4704848.239967344%5D%2C%5B530845.8090736413%2C4704846.202005719%5D%2C%5B530859.7323125005%2C4704844.277828193%5D%2C%5B530894.8084794112%2C4704836.453192918%5D%2C%5B530911.8318628%2C4704834.586988901%5D%2C%5B530925.391418464%2C4704833.117328322%5D%2C%5B530938.4709420372%2C4704831.697046953%5D%2C%5B530997.6664402845%2C4704826.583654985%5D%2C%5B531004.3208771289%2C4704825.8189267125%5D%2C%5B531056.1680774698%2C4704819.827527231%5D%2C%5B531075.0110539302%2C4704817.1607856555%5D%2C%5B531086.1425600447%2C4704815.577638997%5D%2C%5B531133.0105129811%2C4704813.793663995%5D%2C%5B531137.3215272503%2C4704813.790858098%5D%2C%5B531196.0809525666%2C4704813.818265993%5D%2C%5B531215.481756981%2C4704815.177531185%5D%2C%5B531251.8480428552%2C4704817.738204427%5D%2C%5B531259.6378745504%2C4704818.942568384%5D%2C%5B531278.6699861528%2C4704821.85223873%5D%2C%5B531285.6926737762%2C4704822.92815513%5D%2C%5B531307.3430518293%2C4704826.342434091%5D%2C%5B531315.6565023499%2C4704827.652180096%5D%2C%5B531334.1866134475%2C4704830.559743493%5D%2C%5B531359.1711836347%2C4704834.496658635%5D%2C%5B531371.467744569%2C4704836.486332753%5D%2C%5B531396.2895786298%2C4704840.488839631%5D%2C%5B531411.1421575735%2C4704843.688942304%5D%2C%5B531423.9224631386%2C4704846.438439111%5D%2C%5B531444.1270589246%2C4704849.58919442%5D%2C%5B531444.2819744216%2C4704849.611957972%5D%2C%5B531463.4635223292%2C4704852.088859494%5D%2C%5B531464.777392517%2C4704852.109500835%5D%2C%5B531485.0983887817%2C4704852.363080732%5D%2C%5B531503.1006766822%2C4704852.7974650655%5D%2C%5B531507.3816105761%2C4704852.912430339%5D%2C%5B531537.2608026981%2C4704851.811954542%5D%2C%5B531566.9333188131%2C4704850.710670417%5D%2C%5B531574.4209627791%2C4704850.163553735%5D%2C%5B531590.260276593%2C4704848.9923570305%5D%2C%5B531604.3597337583%2C4704848.953311639%5D%2C%5B531613.8085721299%2C4704848.929972021%5D%2C%5B531635.4377383711%2C4704850.4623175105%5D%2C%5B531656.9866662326%2C4704851.781074174%5D%2C%5B531665.0231971837%2C4704852.280939868%5D%2C%5B531675.4419329794%2C4704853.2476433385%5D%2C%5B531711.9294141822%2C4704856.679133731%5D%2C%5B531716.4073389923%2C4704857.302609593%5D%2C%5B531753.6395338628%2C4704862.532292628%5D%2C%5B531776.2208023029%2C4704865.702189996%5D%2C%5B531815.5633616754%2C4704869.478205057%5D%2C%5B531839.4329191202%2C4704871.793668223%5D%2C%5B531854.7772663479%2C4704873.9378539855%5D%2C%5B531877.8305773996%2C4704877.176427822%5D%2C%5B531904.9079545888%2C4704883.419564002%5D%2C%5B531914.1401639611%2C4704885.5579640325%5D%2C%5B531924.1605178574%2C4704888.067727809%5D%2C%5B531933.0600703382%2C4704890.307595581%5D%2C%5B531946.6490047864%2C4704893.731031759%5D%2C%5B531949.0677502435%2C4704894.271667376%5D%2C%5B531979.3394855217%2C4704900.91217483%5D%2C%5B531996.750095033%2C4704904.779821018%5D%2C%5B532007.20678592%2C4704907.100476142%5D%2C%5B532022.289233658%2C4704913.200709586%5D%2C%5B532035.7428237612%2C4704918.749227429%5D%2C%5B532044.3432801174%2C4704926.621632384%5D%2C%5B532054.2634112479%2C4704938.059827101%5D%2C%5B532063.930120435%2C4704956.439756738%5D%2C%5B532067.340794292%2C4704964.391240239%5D%2C%5B532077.901247484%2C4704989.04882524%5D%2C%5B532078.3886667266%2C4704990.602917608%5D%2C%5B532085.9974234862%2C4705015.033551502%5D%2C%5B532089.3871495009%2C4705025.9194081435%5D%2C%5B532096.0473845542%2C4705046.322557757%5D%2C%5B532113.0213579335%2C4705098.398112976%5D%2C%5B532116.6535544187%2C4705112.712219232%5D%2C%5B532123.9975034106%2C4705141.686382309%5D%2C%5B532132.8564510583%2C4705176.661371726%5D%2C%5B532143.1218365126%2C4705217.158561241%5D%2C%5B532145.6518342467%2C4705227.15763082%5D%2C%5B532147.5084969545%2C4705234.307398215%5D%2C%5B532154.7895882544%2C4705262.449752989%5D%2C%5B532164.7176433109%2C4705300.812148259%5D%2C%5B532172.3496030723%2C4705326.47009552%5D%2C%5B532177.3435797786%2C4705338.348408841%5D%2C%5B532180.4976990082%2C4705345.842364711%5D%2C%5B532194.3775773768%2C4705377.140385612%5D%2C%5B532194.3923056282%2C4705377.147807988%5D%2C%5B532198.2901615279%2C4705388.212012525%5D%2C%5B532203.2080008073%2C4705402.171157676%5D%2C%5B532215.4700279853%2C4705436.910648239%5D%2C%5B532221.6481897096%2C4705454.449703578%5D%2C%5B532226.2601149373%2C4705467.5027491385%5D%2C%5B532226.3984836525%2C4705467.907872026%5D%2C%5B532233.3816618244%2C4705486.928781757%5D%2C%5B532236.5305828127%2C4705495.518359064%5D%2C%5B532250.306960195%2C4705533.110523375%5D%2C%5B532252.6467665068%2C4705539.490059351%5D%2C%5B532256.741849518%2C4705550.959434532%5D%2C%5B532265.6821280301%2C4705576.078430585%5D%2C%5B532265.7767176275%2C4705576.373033493%5D%2C%5B532277.109242946%2C4705598.120147455%5D%2C%5B532277.7604522015%2C4705599.351298639%5D%2C%5B532284.6098370609%2C4705612.142380506%5D%2C%5B532293.3984898321%2C4705628.531219966%5D%2C%5B532296.9679772528%2C4705633.938294282%5D%2C%5B532310.871973013%2C4705655.02063589%5D%2C%5B532314.1335875974%2C4705659.962967096%5D%2C%5B532321.248427069%2C4705669.6003313195%5D%2C%5B532325.2387137054%2C4705674.979925046%5D%2C%5B532330.7619232633%2C4705682.447815603%5D%2C%5B532338.1409230079%2C4705692.409968727%5D%2C%5B532347.887086765%2C4705704.412806714%5D%2C%5B532352.0923651311%2C4705709.580122342%5D%2C%5B532354.8371304485%2C4705712.960991446%5D%2C%5B532368.502315183%2C4705729.769455396%5D%2C%5B532373.2129722916%2C4705734.181655699%5D%2C%5B532384.1113349565%2C4705744.402819155%5D%2C%5B532391.2636579066%2C4705749.11317564%5D%2C%5B532394.6411859852%2C4705751.327707091%5D%2C%5B532394.9213797835%2C4705751.387841367%5D%2C%5B532411.2323761046%2C4705754.7214931445%5D%2C%5B532430.2225936541%2C4705753.302300667%5D%2C%5B532438.910651537%2C4705749.967285965%5D%2C%5B532443.4801552194%2C4705748.22361552%5D%2C%5B532444.5469173042%2C4705747.38287919%5D%2C%5B532463.5708216684%2C4705732.403240014%5D%2C%5B532478.760849437%2C4705714.9568720525%5D%2C%5B532480.1113464171%2C4705713.418831411%5D%2C%5B532489.7897545771%2C4705700.322377099%5D%2C%5B532497.5220506416%2C4705689.871631122%5D%2C%5B532504.870632222%2C4705677.823265637%5D%2C%5B532506.4697861655%2C4705675.19798656%5D%2C%5B532508.0824979431%2C4705671.249045436%5D%2C%5B532512.7266153495%2C4705659.857255887%5D%2C%5B532513.1296404604%2C4705658.903111426%5D%2C%5B532513.9687488682%2C4705656.237510112%5D%2C%5B532518.4931070016%2C4705642.043245605%5D%2C%5B532520.6579175048%2C4705635.250842817%5D%2C%5B532521.6316373163%2C4705632.210804194%5D%2C%5B532525.5517884713%2C4705603.570241914%5D%2C%5B532527.1798728413%2C4705591.590652333%5D%2C%5B532529.1820206046%2C4705576.957950016%5D%2C%5B532530.5212669793%2C4705562.027957108%5D%2C%5B532531.0035699756%2C4705556.7425791705%5D%2C%5B532531.6420758775%2C4705549.619388192%5D%2C%5B532532.2969243017%2C4705542.157974872%5D%2C%5B532537.9489701745%2C4705522.011869717%5D%2C%5B532538.947397066%2C4705518.427689668%5D%2C%5B532539.5479710903%2C4705516.268362882%5D%2C%5B532539.6523692764%2C4705516.040870533%5D%2C%5B532547.0213379672%2C4705498.101623895%5D%2C%5B532553.3312985454%2C4705487.239508614%5D%2C%5B532556.8806921776%2C4705481.122669367%5D%2C%5B532570.4671868272%2C4705461.072324185%5D%2C%5B532574.6406169458%2C4705457.260268887%5D%2C%5B532576.8421695105%2C4705455.262850079%5D%2C%5B532579.5701150284%2C4705452.767803097%5D%2C%5B532581.171261733%2C4705451.311792273%5D%2C%5B532614.9808899913%2C4705428.436384534%5D%2C%5B532616.380316952%2C4705427.501586559%5D%2C%5B532620.4973395104%2C4705424.711521708%5D%2C%5B532650.8984239028%2C4705406.276953131%5D%2C%5B532658.3078816613%2C4705401.832901474%5D%2C%5B532662.379029601%2C4705399.388288445%5D%2C%5B532663.7335962058%2C4705398.578309005%5D%2C%5B532666.5463759934%2C4705396.892647657%5D%2C%5B532683.8820228624%2C4705386.501382769%5D%2C%5B532692.0126341059%2C4705379.3911131425%5D%2C%5B532701.2224678856%2C4705368.80730509%5D%2C%5B532703.0407148404%2C4705366.7124947%5D%2C%5B532714.1504770415%2C4705353.938646973%5D%2C%5B532715.0781606977%2C4705352.869265257%5D%2C%5B532732.0294319022%2C4705330.062052436%5D%2C%5B532737.4817589961%2C4705322.733273926%5D%2C%5B532743.9370539383%2C4705314.026576733%5D%2C%5B532767.7671897524%2C4705281.962998484%5D%2C%5B532776.5168366616%2C4705268.832335416%5D%2C%5B532785.2517193072%2C4705255.708943284%5D%2C%5B532795.2429626674%2C4705240.701347948%5D%2C%5B532798.2984336616%2C4705236.089757346%5D%2C%5B532810.5072632123%2C4705218.856809451%5D%2C%5B532812.1271529073%2C4705216.577185082%5D%2C%5B532831.7223052254%2C4705188.9282187885%5D%2C%5B532843.2364126084%2C4705173.479093668%5D%2C%5B532844.6775076124%2C4705171.551637833%5D%2C%5B532848.1317377925%2C4705166.919838454%5D%2C%5B532852.3214062974%2C4705161.298638285%5D%2C%5B532852.4699346707%2C4705161.10811976%5D%2C%5B532871.1509826288%2C4705139.52962535%5D%2C%5B532873.3931660871%2C4705136.782230329%5D%2C%5B532886.2375939655%2C4705121.02308617%5D%2C%5B532887.2528009657%2C4705120.189451579%5D%2C%5B532911.0235085007%2C4705100.988437923%5D%2C%5B532929.4321896306%2C4705085.571820281%5D%2C%5B532934.3012164094%2C4705081.483580285%5D%2C%5B532940.6767107688%2C4705075.703536186%5D%2C%5B532952.8124278929%2C4705064.699496252%5D%2C%5B532957.1622074641%2C4705061.153050209%5D%2C%5B532967.3883102124%2C4705052.809731518%5D%2C%5B532973.5906743526%2C4705047.749633485%5D%2C%5B532997.8794774082%2C4705028.359939609%5D%2C%5B533010.1920706846%2C4705017.452371628%5D%2C%5B533014.6398545457%2C4705013.487181683%5D%2C%5B533038.588215767%2C4704995.890476164%5D%2C%5B533042.4791023876%2C4704992.621352188%5D%2C%5B533046.7924836165%2C4704988.986494736%5D%2C%5B533055.5969746578%2C4704981.599948854%5D%2C%5B533061.3702204721%2C4704976.773192756%5D%2C%5B533067.453289966%2C4704971.99203666%5D%2C%5B533079.4267655284%2C4704962.590620887%5D%2C%5B533087.540055257%2C4704956.208411389%5D%2C%5B533090.9693138832%2C4704953.782904283%5D%2C%5B533113.2487954709%2C4704937.9508838365%5D%2C%5B533117.382782848%2C4704934.800605663%5D%2C%5B533149.2100527837%2C4704910.570688427%5D%2C%5B533152.5585075509%2C4704908.071262488%5D%2C%5B533181.0280270547%2C4704886.789431716%5D%2C%5B533184.9403811648%2C4704883.689598581%5D%2C%5B533201.1529055312%2C4704870.859018653%5D%2C%5B533207.9624753711%2C4704865.470916031%5D%2C%5B533225.2635406104%2C4704853.491357325%5D%2C%5B533225.6784571732%2C4704853.169719995%5D%2C%5B533239.1784506589%2C4704842.628325541%5D%2C%5B533242.6831436615%2C4704839.886950875%5D%2C%5B533245.2390885474%2C4704837.95744633%5D%2C%5B533255.3367616977%2C4704830.371218824%5D%2C%5B533255.7370580086%2C4704830.020092742%5D%2C%5B533268.1908348073%2C4704819.076560002%5D%2C%5B533271.9788651806%2C4704815.748148235%5D%2C%5B533277.8135948267%2C4704810.473095208%5D%2C%5B533282.4028646656%2C4704806.310046985%5D%2C%5B533283.8634570983%2C4704804.978421969%5D%2C%5B533294.9617533135%2C4704793.4694467215%5D%2C%5B533300.2312522217%2C4704787.537103127%5D%2C%5B533305.3300308499%2C4704781.80252677%5D%2C%5B533307.5713757839%2C4704779.290482271%5D%2C%5B533310.4599267108%2C4704775.737124075%5D%2C%5B533321.2488792022%2C4704762.55708005%5D%2C%5B533321.8431834636%2C4704761.772937274%5D%2C%5B533331.5536291216%2C4704748.756891217%5D%2C%5B533339.5330338728%2C4704738.056739216%5D%2C%5B533350.3511779241%2C4704723.427866087%5D%2C%5B533356.6816671845%2C4704714.852766814%5D%2C%5B533371.6184961355%2C4704695.712873278%5D%2C%5B533372.3019221022%2C4704694.81882794%5D%2C%5B533383.0729865639%2C4704680.800159527%5D%2C%5B533397.0098283909%2C4704663.942871057%5D%2C%5B533405.0106737908%2C4704654.971214493%5D%2C%5B533410.3618535775%2C4704648.980384703%5D%2C%5B533423.0098472277%2C4704631.521126315%5D%2C%5B533431.8384735342%2C4704619.280389555%5D%2C%5B533433.6367535437%2C4704616.817686794%5D%2C%5B533442.9100626374%2C4704604.218668139%5D%2C%5B533451.5792454269%2C4704589.836787253%5D%2C%5B533457.2481833915%2C4704582.258742316%5D%2C%5B533463.8830049499%2C4704573.390817219%5D%2C%5B533471.4818099792%2C4704559.018468217%5D%2C%5B533471.8766933951%2C4704558.26277816%5D%2C%5B533477.8684457315%2C4704541.889421702%5D%2C%5B533486.992857577%2C4704523.442192343%5D%2C%5B533487.6068412983%2C4704521.643107008%5D%2C%5B533493.3277875567%2C4704504.797639454%5D%2C%5B533495.2016506934%2C4704497.370467979%5D%2C%5B533497.2790043615%2C4704489.076343944%5D%2C%5B533499.6264419901%2C4704476.811651269%5D%2C%5B533499.8285337576%2C4704462.410942856%5D%2C%5B533498.9735470328%2C4704445.2321669385%5D%2C%5B533496.3213106197%2C4704427.213558173%5D%2C%5B533495.2036292348%2C4704420.14705196%5D%2C%5B533493.397758367%2C4704408.811121734%5D%2C%5B533492.9202909826%2C4704406.778746513%5D%2C%5B533488.7003884815%2C4704389.296808508%5D%2C%5B533482.3665463714%2C4704370.811695805%5D%2C%5B533480.498044712%2C4704366.360055158%5D%2C%5B533473.3592865352%2C4704349.452441721%5D%2C%5B533468.6672295276%2C4704338.036346466%5D%2C%5B533462.8732216721%2C4704323.9522724105%5D%2C%5B533462.236722386%2C4704322.750277906%5D%2C%5B533454.5476380449%2C4704308.201044403%5D%2C%5B533443.2517399533%2C4704286.82330227%5D%2C%5B533441.697530452%2C4704284.557709472%5D%2C%5B533432.6579391013%2C4704271.428912034%5D%2C%5B533430.3327441475%2C4704268.291668939%5D%2C%5B533421.9484899112%2C4704257.049012565%5D%2C%5B533413.8590564941%2C4704247.440690286%5D%2C%5B533409.2197298486%2C4704241.931224151%5D%2C%5B533399.0690578741%2C4704231.091999094%5D%2C%5B533398.9369159123%2C4704230.9368994245%5D%2C%5B533389.7167424874%2C4704223.110553522%5D%2C%5B533378.6232485555%2C4704216.437420329%5D%2C%5B533367.2435354037%2C4704210.947175586%5D%2C%5B533365.8735152762%2C4704210.293327662%5D%2C%5B533358.9421249531%2C4704208.58308371%5D%2C%5B533353.1609718446%2C4704207.172572651%5D%2C%5B533335.5406536304%2C4704205.2567494055%5D%2C%5B533321.7297316417%2C4704203.33711207%5D%2C%5B533309.6598106099%2C4704201.683265972%5D%2C%5B533298.4264144785%2C4704201.092639818%5D%2C%5B533289.7171890349%2C4704200.639130477%5D%2C%5B533272.8080131445%2C4704199.75664196%5D%2C%5B533256.9701190537%2C4704198.702771323%5D%2C%5B533241.3597596514%2C4704196.377505829%5D%2C%5B533229.0198675415%2C4704192.501123859%5D%2C%5B533209.329926831%2C4704186.449264935%5D%2C%5B533190.9866990137%2C4704179.741865047%5D%2C%5B533172.8169735444%2C4704173.8003162425%5D%2C%5B533153.4473133127%2C4704165.580218917%5D%2C%5B533138.1697414011%2C4704158.453538863%5D%2C%5B533135.3698795693%2C4704157.292752548%5D%2C%5B533121.1128359518%2C4704151.347853662%5D%2C%5B533112.5635106508%2C4704146.74674743%5D%2C%5B533107.8507423087%2C4704144.201380456%5D%2C%5B533092.4396003495%2C4704137.199191891%5D%2C%5B533091.5122420493%2C4704136.598982537%5D%2C%5B533086.2794956357%2C4704133.168480783%5D%2C%5B533079.398103515%2C4704128.670944128%5D%2C%5B533075.1927453171%2C4704126.539917488%5D%2C%5B533068.1887193186%2C4704122.990685859%5D%2C%5B533056.2518383928%2C4704111.922644095%5D%2C%5B533046.9107053138%2C4704104.581528248%5D%2C%5B533038.6933352568%2C4704095.340621057%5D%2C%5B533031.3712742646%2C4704087.229375227%5D%2C%5B533022.1114372669%2C4704076.740411875%5D%2C%5B533011.5208107814%2C4704061.971471371%5D%2C%5B533001.8314692555%2C4704047.067024257%5D%2C%5B532991.218917283%2C4704030.672328562%5D%2C%5B532984.5677972387%2C4704016.481017223%5D%2C%5B532976.1190530905%2C4703999.927329755%5D%2C%5B532965.1485860735%2C4703976.447232073%5D%2C%5B532963.4316908392%2C4703972.62880351%5D%2C%5B532957.440373188%2C4703959.396779852%5D%2C%5B532951.0691686103%2C4703945.309663607%5D%2C%5B532948.2916482372%2C4703939.397148584%5D%2C%5B532938.9433299041%2C4703919.44066533%5D%2C%5B532932.9424516755%2C4703906.649871651%5D%2C%5B532929.8178446988%2C4703900.750404078%5D%2C%5B532923.6491643884%2C4703889.091600933%5D%2C%5B532917.2171170346%2C4703876.916626809%5D%2C%5B532899.9482494118%2C4703845.697464498%5D%2C%5B532874.4966685716%2C4703799.301001051%5D%2C%5B532861.4600491391%2C4703775.450218494%5D%2C%5B532856.2995376664%2C4703766.0101871025%5D%2C%5B532850.9705586942%2C4703756.282467766%5D%2C%5B532846.6663951023%2C4703748.420647321%5D%2C%5B532843.2187730233%2C4703742.100271011%5D%2C%5B532839.5313217121%2C4703734.9695945885%5D%2C%5B532829.0033003199%2C4703714.55105307%5D%2C%5B532821.0285093602%2C4703699.102499406%5D%2C%5B532814.9925316488%2C4703687.407307256%5D%2C%5B532813.4413765721%2C4703684.420781655%5D%2C%5B532807.8587184119%2C4703673.661932935%5D%2C%5B532803.0224570937%2C4703664.318961944%5D%2C%5B532798.0968729676%2C4703656.696899164%5D%2C%5B533062.3297272363%2C4703523.031938498%5D%2C%5B533111.4067746777%2C4703630.180279109%5D%2C%5B533393.7271417098%2C4703960.759478816%5D%2C%5B533584.1197757068%2C4704423.98777771%5D%2C%5B533709.6317193415%2C4704712.888089437%5D%2C%5B533521.9376962279%2C4705297.44226908%5D%2C%5B533242.5176159221%2C4705561.623076389%5D%2C%5B533312.5292256422%2C4706002.722172272%5D%2C%5B533291.4934164124%2C4706166.651155156%5D%2C%5B533251.5885414933%2C4706641.048035204%5D%2C%5B533191.0604751842%2C4707009.143421168%5D%2C%5B532873.4094909984%2C4707368.281552164%5D%2C%5B532618.8188147683%2C4707743.59779733%5D%2C%5B532499.7881833084%2C4707990.992862468%5D%2C%5B532175.7318167686%2C4708228.836825789%5D%2C%5B531722.6470498778%2C4708332.770407534%5D%2C%5B531538.9474552167%2C4708749.406680503%5D%2C%5B531272.8022130775%2C4708567.690385124%5D%2C%5B530935.0692955813%2C4708475.462449825%5D%2C%5B530552.7475052424%2C4708318.09887358%5D%2C%5B530367.8384311709%2C4708229.772995629%5D%2C%5B530154.3090925604%2C4708070.481138222%5D%2C%5B529800.2083389944%2C4707897.45924378%5D%2C%5B529536.8366353745%2C4707619.438971409%5D%2C%5B529294.7678522613%2C4707613.718488938%5D%2C%5B529072.9235052852%2C4707583.432361506%5D%2C%5B528874.4097351268%2C4707455.202931092%5D%2C%5B528751.4584211947%2C4707330.5969750015%5D%5D%5D%7D
