Permission requirements for REST API calls to generateToken
2802
6
01-24-2023 09:07 AM
WarrenMedernach
I'm struggling with getting a non Portal site admin user account to be able to generate a token?
Using Postman if I generate a POST call with the username and password of the Portal Site Admin in the body to: https://<URL>/arcgis/tokens/generateToken I get a valid token back:
If I do this exact same call with a different user it reports back:
You are not authorized to access this information
 Are there specific access requirements to be able to acquire a token?
Tags (3)
shahkunal
Hello @WarrenMedernach ,
I think you need to use generateToken REST URL of your organization portal which will be https://<domain>/portal/sharing/rest/generateToken. Before that you need to create user in your organization with specific role and then hit above URL with the credentials
shahkunal
Gordon_Aberdeen
Did you ever solve this Warren?
WarrenMedernach
Hi Gordon,
Unfortunately no, I never did get past having to use an 'admin' level user to return a token.
Trevor_Hart
@WarrenMedernach I believe @shahkunal was correct. You appear to be requesting a token from the ArcGIS Server end point. If your ArcGIS Server is federated you will need to generate a token from the Portal end point. This will be valid for the ArcGIS Server once generated.
Remember, a federated ArcGIS Server doesnt know anything about any users except the admin user it was configured with - hence the error.
WarrenMedernach
Thanks for the confirmation/reminder Trevor.  I have confirmed that a non-admin can indeed authenticate through the Portal generatetoken call.
SamanthaO_Neil1
Do you recall what credentials in portal are being used(outside of full admin) to generate the token?
