Index (zero based) must be greater than or equal to zero and less than the size of th
4618
12-22-2012 06:27 PM
XintaoLiu
I am using ArcGIS 10.1 and VS2010 C# to create a SOE project. After I created a demo project (see attached picture) and then build up the project, I got the following error:
Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
I just got confused, because I did nothing after I created the project. Any suggestion? Thanks in advance!
[ATTACH=CONFIG]20158[/ATTACH]
XintaoLiu
Please provide a screen shot of the error.  I did not see it in the image you provided.
Commented out this line  //Date = "12/22/2012 11:09:57 PM", in the AssemblyInfo.cs file, then the problem is fixed!
This is because the local date format is different with the one of VS2010.
RichardWatson
XintaoLiu
