I am attempting to delete some rows from a table--
681
12-13-2024 11:09 AM
JeffSilberberg
I have a table created by Surevy 123 that has ended up with a duplicate row in it -- That's a separate issue.
I can go the ArcGIS REST Services Directory for the specific Layer -
I can QUERY the Table and list the Duplicate ROWS with the globalId and ObjectId of each duplicate.
But, if I go then go to the DELETE FEATURES and specify WHERE GLOBALID = {ID FROM QUERY}.
I get back an error indicating invalid QUERY.  I also tried specifying both the OBJECT ID and GLOBALID from the QUERY but had the same result.  Note I also checked the Table settings and the Delete capability is active.
TIA --
MobiusSnake
MVP Regular Contributor
Are you including single quotes around your Global ID?  The query should be something like this:
GLOBALID = '00000000-0000-0000-0000-000000000000'
MobiusSnake
JeffSilberberg
No, I probably wasn't.  Will try that on Monday..
Thank you --
