How to Start and Stop ArcGis Map Services
4362
08-29-2012 03:38 AM
pavan_kumarmuttigi
I am new to the ArcGis Server.Can any one tell me how to start and stop the ArcGis Map Service programmatically in Java using RestFul Web Services.
Thanks in Advance
nicogis
MVP Alum
Are you using 10 or 10.1?
If you use 10.1 you can see help http://resources.arcgis.com/en/help/server-admin-api/
For example: start service: http://resources.arcgis.com/en/help/server-admin-api/startService.html
you call via http and parse response in json (f=json)
for java you can see http://www.json.org/java/
pavan_kumarmuttigi
Thank You Domenico Ciavarella
Very helpful info
Thanks once again
nicogis
MVP Alum
extra info: this is code in c# (but you can translate in java) for image service but you can see method for your service map
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/0001/000100000262000000.htm
nicogis
MVP Alum
