Can't specify GeoTransformation to the project geometry service function as with SOAP
3022
07-13-2012 08:13 AM
NickDodd
We currently have a java client which performs coordinates transformations via the Geometry Services SOAP client, but a client has requested we use the REST api instead.
With the SOAP interface we have used JAX libraries to generate java stubs and this lets us specify the following parameters:
  1. InSpatialReference
  2. OutSpatialReference
  3. TransformForward
  4. Transformation
  5. Extent
  6. InGeometryArray
Where Transformation is a GeoTransformation WKID or WKT object.
However - the following REST api documentation makes no mention of this: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/project.html
You can only specify the input/output spatial references, the input geometries to work on and the return type.
Am I missing something?
nicogis
your link is help for rest ags 10.
The geotrasformation in project geometry rest has been added in 10.1 for rest : http://resources.arcgis.com/en/help/rest/apiref/project.html
NickDodd
Thanks, looks like we require our client to upgrade then!
