Alphanumeric Editing of non-SDE data.
1276
01-10-2012 07:04 AM
TiagoRibeiro
I posted this problem in the JavaScript forum, and there advised me to posted here. This was the thread http://forums.arcgis.com/threads/45064-Alphanumeric-Editing-of-non-SDE-data..
I'm trying to edit alphanumeric data residing in another database, not SDE. I created a view from the table I want to edit in the SDE database, registered it, and using ArcMap I can now edit the data with no problem, but when I try to edit using the JavaScript API, with the AttributeInspector Widget, the server gives a error, but applies the edits anyway, and locks the table. I have to manually stop the service to access the data.
The server logs say:
<Msg time='2012-01-10T12:13:57' type='ERROR' code='100005' target='ARH_PROCESSOS_ALFA.MapServer' methodName='GraphicFeatureServer.ApplyEdits' machine='WKLAB10' user='?' process='8144' thread='8180' elapsed='0.03620'>Method failed.HRESULT = 0x80070057 : The parameter is incorrect.  .</Msg>.
Is there anyway to get around this? Please help me out, and if you need anymore information please let me know!
Thanks!
TiagoRibeiro
I've been doing some tests, and now I'm really confused!!
I've created two simple tables in the SDE Geodatabase, one using ArcMAP, and the other I used the SQL Server Manager and then registered it in the geodatabase, I was able to edit them booth using ArcMap and the REST end points, and I can't see the difference between this and editing the view... any ideas anyone?? Please!!
