Access Pooling Properties - Dedicated/Shared - via REST API
3977
11
10-02-2023 10:35 PM
MatthewGeorge
Is it possible access the pooling properties for an Map/Feature Service via the REST API? I can see that it's possible to get/set the min/max instances but I can't see any properties that indicate if it is a shared or dedicated instance.
Trevor_Hart
These are both 10.9.1
if you are seeing 1/2 then it’s likely not shared.
MatthewGeorge
We're on 10.8.1. They're shared instances according to AGS Manager.
