POST Token returns "Process finished with exit code 0"
1517
6
11-30-2020 03:20 AM
CliveSwan
Occasional Contributor II
Greetings
I am working on an ESRI Hosted site.
I am trying to automate the ESRI token web page Generate Token form ie:
I used a Python POST:
user_name  = 'me'
pass_word = 'my password'
referer = 'https://company.cloud.esriuk.com'
referer_name = 'https://company.cloud.esriuk.com/portal/sharing/rest/generateToken'
token = ''
expires = 90
##data = {username=user_name,password=pass_word, client=referer, referer=url, expiration=90, f=json}
requests.post(user=user_name, password=pass_word, client=referer, referer=referer_name, expiration=90, f=json)
print("Generating token")
I also tried:
gis_server = GIS(url=f"server_base_url/web_adaptor/admin",
token_url=f"server_base_url/web_adaptor/tokens/generateToken",
username="admin_user",
password="admin_password")
print(token)
I just get the process finished, no output??
Any suggestions?
Regards,
Clive
Tags (3)
CliveSwan
Greetings,
I found this link that solves the problem. Short simple and does what needs to be done.
https://developers.arcgis.com/documentation/core-concepts/security-and-authentication/accessing-arcg...
DavidPike
MVP Frequent Contributor
import requests
portalUrl = "https://domain/portal"
username = 'username'
password = "password"
def generateToken(username, password, portalUrl):
    # Retrieves a token to be used with API requests.
    headers = {'content-type': 'application/x-www-form-urlencoded'}
    parameters = {'username': username,
                  'password': password,
                  'client': 'referer',
                  'referer': portalUrl,
                  'expiration': 60,
                  'f': 'json'}
    url = portalUrl + '/sharing/rest/generateToken?'
    response = requests.post(url, data=parameters, headers=headers)
    try:
        jsonResponse = response.json()
        if 'token' in jsonResponse:
            return jsonResponse['token']
        elif 'error' in jsonResponse:
            print (jsonResponse['error']['message'])
            for detail in jsonResponse['error']['details']:
                print (detail)
    except ValueError:
        print('An unspecified error occurred.')
        print(ValueError)
token = generateToken(username, password, portalUrl)
print(token)
CliveSwan
Hi David,
Thanks for the response.
I am getting a HTTP:400 error now, stating that the client_id is not specified??
I have hardcoded the  client/client_id/referer as company name and/or the base URL. But still keep getting the 'client_id 'not specified' error message??
Odd.
Clive
DavidPike
I'm not sure what you mean exactly, you shouldn't need to modify anything within the generate token function itself.
I'm guessing you have the esri arcgis GIS module in your library?  You could:
from arcgis.gis import GIS
#params
portal_url = "https://domain/portal"
username = "me"
password = "P@ssword123"
#do stuff
connection = GIS(portal_url, username, password)
token = connection._con.token
print(token)
JoshuaBixby
MVP Esteemed Contributor
Since client/client_id/referer are not the same thing, can you share your code again?
CliveSwan
Hi Joshua,
The client is a Webapp URL: https://company.cloud.esriuk.com/
The code is:
username = 'me'
password = 'my password
referer = "https://company.maps.arcgis.com"
portalUrl = "https://company.cloud.esriuk.com/portal"
tokenURL = "https://company.cloud.esriuk.com/portal/sharing/rest/generateToken"
print("START Generate Token")
def generateToken(user_name, pass_word, portalUrl):
parameters = {'username': username, 'password': password, 'client': 'referer', 'referer': portalUrl, 'expiration': 60, 'f': 'json'}
url = 'https://eiffagekier.maps.arcgis.com/sharing/rest/oauth2/token'
#print(response) ### >>>> ### GET error
try:
print(jsonResponse)
print (detail)
except ValueError:
print('An Error occurred.')
print(ValueError)
token = generateToken(username, password, tokenURL) #### portalUrl
print(token)
print("END Generate Token")
Clive
CliveSwan
Greetings,
