Non-Optimized Map Service - No Field Aliases
599
02-08-2011 12:39 PM
PeterMcAlenney
With ArcGIS Server 9.3.1, the REST API does not honor field aliases set in an MXD if the map service is based on the MXD, and not an MSD (optimized map service).
If this a bug or can anyone help me get the REST API to show the field aliases.  I cannot do an MSD due to some complexities in my MXD.
RaviNarayanan
Not sure if you have 9.3.1 SP1 installed. A fix for this issue was included in SP1.
NIM045491 - Field alias is not returned in the layer description (html or json).
http://gisupdates.esri.com/931sp1/ArcGIS/ArcGIS-931sp1-issues.htm#REST-sp1
