mosaic dataset image service turn red when it zooms in to 1:25000 scale
2086
04-30-2012 08:07 AM
MikeJun
New Contributor II
I don't see any problem on mosaic dataset itself however when I published to image service and zoom in more than 1:25,000 scale, it started turning red, black and missing images.
Any ideas?
Mosaic Dataset:
# band = 3
pixel type: unsigned integer
pixel depth: 8 bit
no data value = 255
ArcGIS Server 10, SP4
ArcGIS Desktop 10, SP4
Winder Server 2008 64 bit
WenxueJu
Mike,
It looks like server doesn't have access to some images. The following steps may help you to troubleshoot:
-- Check the user that runs ArcGIS Server (you can either check windows services, or view the user that runs arcsoc.exe in taskmanager)
-- Check source raster paths (if you're not sure about the path, you can attempt to repair mosaic on mosaic dataset's context menu, and see the paths -- don't do reapir unless you need to)
-- Check permission on source raster folder, make sure the user that runs ArcGIS Server has access, grant that if not already.
